1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: CAC problem between RTEMS and vxWorks
To: Jeff Hill <[email protected]>, Dirk Zimoch <[email protected]>, Benjamin Franksen <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Fri, 21 Sep 2012 10:33:20 -0400 (EDT)
Jeff and Dirk - thanks for getting back to me.
I'm familiar with some of the issues that you guys pointed out, they can definitely bite you.  While double-checking your suggestions I found that one of the channels that was being monitored came from another vxWorks IOC (mistake on my part).  Surprise, surprise...it never has any disconnect issues.  Following that lead, I found that the problems seem to be centered around a dynamically assigned pv in one of my two sequencers.  When I hard-coded that pv assignment the problems went away.  This remains consistent.  What's confusing me a bit is that I use dynamic assignment in the working sequencer, I just don't do any reassignments.
Ben - Any known issues with dynamic assignment/reassignment?  Perhaps specific to RTEMS?
Thanks guys,
Wesley
----- Original Message -----
> From: "Dirk Zimoch" <[email protected]>
> To: "Jeff Hill" <[email protected]>
> Cc: "Wesley Moore" <[email protected]>, "EPICS tech-talk" <[email protected]>
> Sent: Friday, September 21, 2012 6:01:07 AM
> Hi Wesley
> Hill, Jeff wrote:
> > Hi Wesley,
> >> TCP 129.57.214.101:1024(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1025(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1026(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1027(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1028(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1029(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1030(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> >> TCP 129.57.214.101:1031(): User="rtems", V4.11, 4 Channels,
> >> Priority=0
> > When abruptly rebooting the RTEMS system the TCP shutdown
> > interactions
> > may not (probably don’t) occur, and when the new instance of the
> > RTEMS
> > system starts up it begins a new CA circuit over TCP. What
> > ephemeral
> > port is assigned to the new circuit (i.e. 1024 through 1031 above)
> > is
> > is an implementation detail of the IP kernel. On some
> > implementations
> > the same port gets reused, and typically TCP detects an attempt to
> > start
> > a new circuit on the same port as a preexisting circuit, and the
> > server
> > side hangs up. Otherwise, the server side waits the duration of a
> > long
> > timeout, in case the client is just temporarily loosing
> > connectivity,
> > before it hangs up. The order of the ephemeral port assignment
> > depends
> > typically on what sockets have been created since rebooting, and so
> > you
> > may get different port assignment orderings if there are many
> > circuits
> > being created shortly after the IOC reboots.
> >> CAC: Unable to connect because "Connection timed out"
> > Make certain that full/half-duplex configuration match between the
> > switches and the IOCs that are involved. If the switch and the IOC
> > don’t
> > match communication can proceed but it can be very slow and
> > unreliable.
> > Sometimes you can see this by watching the beacons with casw. On
> > vxWorks
> > you can sometimes see the Ethernet auto-negotiation parameters by
> > typing
> > ifShow. In my experience, some of the vxWorks Ethernet drivers are
> > neglecting to turn on the continuous auto-negotiation option in the
> > PHY
> > and so if the vxWorks system gets powered up before the switch it
> > decides
> > to default the auto-negotiation parameters, and never tries to
> > auto-negotiate again. This can be a problem because switches are
> > typically set to continuously auto-negotiate.
> > Another possibility is too many collisions which can be sometimes
> > seen
> > on vxWorks systems with ifShow, but this is an infrequently
> > experienced
> > problem today, on modern switched Ethernet networks.
> > Jeff
> Keep in mind that the number of file descriptors in vxWorks is
> limited
> and each "dead" socket connection uses one. The default number is 50.
> Once they are used up, no new network connection can be made (and no
> file can be opened). Modify NUM_FILES in the vxWorks BSP
> configuration.
> But even worse, vxWorks may run out of network buffers. If the RTEMS
> system has monitors on its 4 channels, then EPICS may try to send the
> monitor events filling the TCP send buffers and using up all
> available
> network buffers.
> So you may check the following:
> * Run inetstatShow and check the Send-Q entries of your "dead"
> sockets
> * Run mbufShow and see if you are short of free buffers
> * Run iosFdShow and see how many file descriptors are in use.
> Jeff, maybe CA should "clean up" the stale sockets instead of waiting
> for TCP to do that (if possible).
> Dirk
> >> -----Original Message-----
> >> From: [email protected]
> >> [mailto:[email protected]]
> >> On Behalf Of Wesley Moore
> >> Sent: Wednesday, September 19, 2012 10:19 AM
> >> To: EPICS tech-talk
> >> Subject: CAC problem between RTEMS and vxWorks
> >> All,
> >> I'm having issues with a RTEMS client (3.14.11) accessing PVs from
> >> a
> >> vxWorks IOC (3.14.8.2).  When the RTEMS IOC is rebooted, sometimes
> >> it
> >> doesn't reconnect to the other IOC.  Even after connecting, I'm
> >> often
> >> getting timeouts on RTEMS and can't seem to maintain a solid
> >> connection
> >> between the two.
> >> # timeouts on RTEMS client IOC
> >> CA.Client.Exception...............................................
> >>     Warning: "Virtual circuit disconnect"
> >>     Context: "iocfel8.acc.jlab.org:5064"
> >>     Source File: ../cac.cpp line 1145
> >>     Current Time: Wed Sep 19 2012 11:52:27.183784942
> >> After reboots, It stacks up new socket connections which isn't
> >> helping
> >> matters.
> >> # casr on vxWorks IOC
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Priority=0
> >> Any help is greatly appreciated.
> >> Wesley
Re: CAC problem between RTEMS and vxWorks J. Lewis Muir
Re: CAC problem between RTEMS and vxWorks Benjamin Franksen
Re: CAC problem between RTEMS and vxWorks Dirk Zimoch
Prev: Re: CAC problem between RTEMS and vxWorks Dirk Zimoch
Next: Re: CAC problem between RTEMS and vxWorks J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
