1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: waveform changes using subArray
To: Hinko Kocevar <[email protected]>
Cc: [email protected]
Date: Mon, 17 Sep 2012 14:02:56 -0500
Hi Hinko,
On 2012-09-17 Hinko Kocevar wrote:
> Can bi, ai, bo, ao and similar live comfortably without their INP/OUT
> links defined? We could also resort to a dummy INP/OUT value that would
> select INST_IO.
The INP/OUT field value string doesn't set the address type, that is
determined by the device() entry in your DBD file that matches the DTYP field
setting for the record instance.  If you don't set INP/OUT and your device
support's init_record() routine doesn't complain about the result then
everything should be fine.
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: waveform changes using subArray Tim Mooney
Re: waveform changes using subArray Andrew Johnson
Re: waveform changes using subArray Hinko Kocevar
Prev: Re: waveform changes using subArray Hinko Kocevar
Next: MVME5500 and Linux John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: waveform changes using subArray Rod Nussbaumer
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
