1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to profile an EPICS application on Linux
Date: Fri, 14 Sep 2012 18:58:35 -0400
It's *supposed* to exit cleanly and usually does for me, but sometimes I've seen it get stuck. I have the same problem with gdb sometimes, more often with our older builds using R3.14.9 and rarely (maybe never) with R3.14.12.2. Sometimes not even a ctrl-C gets me out and I have to 'kill' the task.
On 9/14/2012 2:09 PM, Mark Rivers wrote:
Hi John,
Thanks that is really useful.  I used the commands:
valgrind --tool=callgrind ../../bin/linux-x86_64/quadEMTestApp st.cmd.AH501
and then
kcachegrind
That is a very nice GUI indeed.
Both tools appear to be installed by default on our Fedora Core 15 system.
I have one question.  I ran the IOC for a while, then I wanted to exit it and look at the statistics that had been collected. However, when I typed "exit" at the iocsh prompt nothing happened.  Valgrind was still using almost 100 of a CPU.  I waited for a minute or so, then killed it with ^C.  That seemed to be OK, since there was a callgrind.out.nnnn file that kcachegrind could read.  But is this normal, why did I have to kill it with ^C?
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of John A. Priller
Sent: Wednesday, September 12, 2012 7:07 AM
To: [email protected]
I've been using valgrind/callgrind to gather performance data:
<http://valgrind.org/docs/manual/cl-manual.html>
There's a very nice GUI tool for viewing the results:
<http://kcachegrind.sourceforge.net/html/Home.html>
These are all available as packages for Debian/Ubuntu (the flavor of
Linux we use for soft IOCs).
On 9/10/2012 5:17 PM, Mark Rivers wrote:
Folks,
I have an EPICS IOC application that is taking a lot of CPU time and I want to figure out where it is spending its time.  The IOC is running on Linux, and it seems like the Linux "gprof" tool should do what I want.
I added the following lines to my application Makefile, and also changed CONFIG to STATIC_BUILD=YES.
USR_CPPFLAGS_Linux += -pg
USR_CFLAGS_Linux += -pg
USR_LDFLAGS_Linux += -pg
The application creates the gmon.out file as expected.  The problem is that the output of gprof seems to have the number of calls to each function correctly, but does not have execution times.
corvette:quadEM/iocBoot/iocTest>gprof -b ../../bin/linux-x86/quadEMTestApp gmon.out | more
Flat profile:
Each sample counts as 0.01 seconds.
    %   cumulative   self              self     total
   time   seconds   seconds    calls  Ts/call  Ts/call  name
100.00      0.01     0.01                             yyerror
    0.00      0.01     0.00 25739421     0.00     0.00  getAddr
    0.00      0.01     0.00 11866294     0.00     0.00  paramList::getParameter(int)
    0.00      0.01     0.00  7586090     0.00     0.00  paramVal::isDefined()
    0.00      0.01     0.00  3706973     0.00     0.00  getTraceMask
    0.00      0.01     0.00  3403295     0.00     0.00  paramVal::getStatus()
    0.00      0.01     0.00  2237527     0.00     0.00  paramList::getInteger(int, int*)
    0.00      0.01     0.00  2237526     0.00     0.00  paramVal::getInteger()
    0.00      0.01     0.00  2235123     0.00     0.00  interruptEnd
    0.00      0.01     0.00  2235122     0.00     0.00  interruptStart
    0.00      0.01     0.00  2143477     0.00     0.00  paramVal::hasValueChanged()
    0.00      0.01     0.00  2143477     0.00     0.00  paramList::registerParameterChange(paramVal*, int)
    0.00      0.01     0.00  2136839     0.00     0.00  paramVal::resetValueChanged()
    0.00      0.01     0.00  2136838     0.00     0.00  paramList::setFlag(int)
    0.00      0.01     0.00  2136837     0.00     0.00  paramVal::setValueChanged()
    0.00      0.01     0.00  2136836     0.00     0.00  paramVal::setDefined(bool)
    0.00      0.01     0.00  1169154     0.00     0.00  asynPortDriver::getIntegerParam(int, int, int*)
    0.00      0.01     0.00  1071776     0.00     0.00  paramVal::setInteger(int)
    0.00      0.01     0.00  1071776     0.00     0.00  paramList::setInteger(int, int)
    0.00      0.01     0.00  1071775     0.00     0.00  asynPortDriver::setIntegerParam(int, int, int)
    0.00      0.01     0.00  1071721     0.00     0.00  asynPortDriver::callParamCallbacks(int, int)
    0.00      0.01     0.00  1071719     0.00     0.00  paramList::callCallbacks(int)
    0.00      0.01     0.00  1071701     0.00     0.00  asynPortDriver::setDoubleParam(int, int, double)
    0.00      0.01     0.00  1071701     0.00     0.00  paramVal::setDouble(double)
    0.00      0.01     0.00  1071700     0.00     0.00  paramList::setDouble(int, double)
    0.00      0.01     0.00  1071673     0.00     0.00  asynPortDriver::callParamCallbacks(int)
    0.00      0.01     0.00  1068372     0.00     0.00  paramList::int32Callback(int, int)
    0.00      0.01     0.00  1068362     0.00     0.00  paramVal::getDouble()
    0.00      0.01     0.00  1068362     0.00     0.00  paramList::getDouble(int, double*)
    0.00      0.01     0.00  1068356     0.00     0.00  paramList::float64Callback(int, int)
    0.00      0.01     0.00  1068349     0.00     0.00  interruptCallbackAverage
    0.00      0.01     0.00   389732     0.00     0.00  asynPortDriver::getIntegerParam(int, int*)
    0.00      0.01     0.00    97846     0.00     0.00  createAsynUser
    0.00      0.01     0.00    97724     0.00     0.00  queueRequest
    0.00      0.01     0.00    97706     0.00     0.00  duplicateAsynUser
    0.00      0.01     0.00    97705     0.00     0.00  disconnect
    0.00      0.01     0.00    97682     0.00     0.00  freeAsynUser
    0.00      0.01     0.00    97679     0.00     0.00  lockPort
    0.00      0.01     0.00    97676     0.00     0.00  asynPortDriver::lock()
    0.00      0.01     0.00    97676     0.00     0.00  asynPortDriver::unlock()
    0.00      0.01     0.00    97675     0.00     0.00  unlockPort
    0.00      0.01     0.00    97667     0.00     0.00  lockPortCallback
    0.00      0.01     0.00    97570     0.00     0.00  readIt
    0.00      0.01     0.00    97444     0.00     0.00  readIt
    0.00      0.01     0.00    97425     0.00     0.00  asynPortDriver::getParamStatus(int, int, asynStatus*)
    0.00      0.01     0.00    97425     0.00     0.00  asynStatus asynPortDriver::doCallbacksArray<int, asynInt32ArrayInterrupt>(int*, unsigned int, int, int, void*)
    0.00      0.01     0.00    97425     0.00     0.00  asynPortDriver::doCallbacksInt32Array(int*, unsigned int, int, int)
    0.00      0.01     0.00    97425     0.00     0.00  drvQuadEM::computePositions(int*)
    0.00      0.01     0.00    97424     0.00     0.00  paramList::getStatus(int, asynStatus*)
    0.00      0.01     0.00    10835     0.00     0.00  paramVal::nameEquals(char const*)
    0.00      0.01     0.00      999     0.00     0.00  getPortName
    0.00      0.01     0.00      988     0.00     0.00  readIt
    0.00      0.01     0.00      970     0.00     0.00  callInterruptUsers
    0.00      0.01     0.00      584     0.00     0.00  paramList::findParam(char const*, int*)
    0.00      0.01     0.00      462     0.00     0.00  asynPortDriver::createParam(int, char const*, asynParamType, int*)
    0.00      0.01     0.00      462     0.00     0.00  paramVal::paramVal(char const*, asynParamType)
    0.00      0.01     0.00      462     0.00     0.00  paramVal::paramVal(char const*)
    0.00      0.01     0.00      462     0.00     0.00  paramList::createParam(char const*, asynParamType, int*)
    0.00      0.01     0.00      396     0.00     0.00  findInterface
    0.00      0.01     0.00      371     0.00     0.00  processAiAverage
    0.00      0.01     0.00      192     0.00     0.00  asynPortDriver::getAddress(asynUser*, int*)
    0.00      0.01     0.00      184     0.00     0.00  memMalloc
    0.00      0.01     0.00      158     0.00     0.00  connectDevice
    0.00      0.01     0.00      144     0.00     0.00  flushIt
    0.00      0.01     0.00      141     0.00     0.00  writeIt
    0.00      0.01     0.00      140     0.00     0.00  writeIt
    0.00      0.01     0.00      128     0.00     0.00  writeRead
    0.00      0.01     0.00      122     0.00     0.00  asynPortDriver::drvUserCreate(asynUser*, char const*, char const**, unsigned int*)
    0.00      0.01     0.00      122     0.00     0.00  asynPortDriver::findParam(int, char const*, int*)
    0.00      0.01     0.00      122     0.00     0.00  drvUserCreate
    0.00      0.01     0.00       94     0.00     0.00  drvAHxxx::writeReadMeter()
    0.00      0.01     0.00       85     0.00     0.00  asynPortDriver::setIntegerParam(int, int)
    0.00      0.01     0.00       65     0.00     0.00  canBlock
    0.00      0.01     0.00       65     0.00     0.00  parseLink
    0.00      0.01     0.00       65     0.00     0.00  skipWhite
    0.00      0.01     0.00       52     0.00     0.00  getCallbackValue
    0.00      0.01     0.00       45     0.00     0.00  connect
    0.00      0.01     0.00       45     0.00     0.00  initCommon
    0.00      0.01     0.00       42     0.00     0.00  asynPortDriver::createParam(char const*, asynParamType, int*)
    0.00      0.01     0.00       30     0.00     0.00  setInputEos
    0.00      0.01     0.00       29     0.00     0.00  addInterruptUser
    0.00      0.01     0.00       29     0.00     0.00  createInterruptNode
    0.00      0.01     0.00       29     0.00     0.00  getInterruptPvt
    0.00      0.01     0.00       28     0.00     0.00  drvAHxxx::setAcquire(int)
    0.00      0.01     0.00       27     0.00     0.00  asynPortDriver::callParamCallbacks()
    0.00      0.01     0.00       26     0.00     0.00  announceExceptionOccurred
Does anyone with gprof experience know why I am not getting the execution times in these functions?
John A. Priller             | Phone : (517) 908-7375
MSU Cyclotron Laboratory    | Fax   : (517) 908-7126
640 S. Shaw Lane room 1300D | Email : [email protected]
East Lansing, MI 48824      | Web   : http://www.nscl.msu.edu/~priller/
How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux John A. Priller
RE: How to profile an EPICS application on Linux Mark Rivers
Prev: Re: Question on configuring soft IOC server ports Ralph Lange
Next: Re: Question on configuring soft IOC server ports Kasemir, Kay
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: How to profile an EPICS application on Linux Mark Rivers
Next: GigE Vision & GeniCam standard SDK (areaDetector) Ahed Aladwan
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
