1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: aSub record : adding arguments
Cc: [email protected]
Date: Fri, 14 Sep 2012 12:15:36 -0400
OK. I think that A..U should be enough for now.
Kate
On 09/14/2012 10:50 AM, Andrew Johnson wrote:
Hi Kate,
On 2012-09-14 Kate Feng wrote:
     Adding arguemnts to the aSub record would facilitate the usage of
the subroutine to
be more globally generic and versatile.  The arguments will be used for
the subroutine.
I don't really understand the purpose of these.  The subroutine already has
direct access to the 21 type-configurable input fields A..U that can be read
from the links INPA..INPU and which are more flexible, why can't it use those
instead?
The aSub record already has 284 fields, 48 of which are links, so each
instance of an aSub record takes up something like 4000 bytes (a bit less on a
32-bit CPU) without including the array storage.  If you want a record type
with a different interface to the subroutine you're welcome to create one and
publish it, but I don't currently see this addition to the aSub making it into
Base without more explanation and a stronger case for it.
- Andrew
aSub record : adding arguments Kate Feng
Re: aSub record : adding arguments Andrew Johnson
Prev: Re: waveform changes using subArray Hinko Kocevar
Next: RE: How to profile an EPICS application on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: aSub record : adding arguments Andrew Johnson
Next: Question on configuring soft IOC server ports Mark Rivers
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
