g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: font init failed
To: tech-talk@aps.anl.gov
Date: Wed, 12 Sep 2012 18:07:34 -0500
Hi Pierrick,
On 2012-09-12 Pierrick Hanlet wrote:
> I have a new machine with a new SLF 6.2 installation on a 64-bit
> machine.  I have the
> same "Font init failed - abort" message as previously mentioned here. I
> found message
> 00357 as a possible solution, but alas, I have no /etc/X11/xorg.conf file.
I assume you mean this particular message 00357 from 2008:
http://www.aps.anl.gov/epics/tech-talk/2008/msg00357.php
> Is there a new solution to this problem?
Does the 'xset fp+' solution shown on that page temporarily solve the problem
i.e. if you manually add each of the paths containing the fonts you need, not
necessarily using the path shown with the xset command in the above message?
We know that the fonts needed for MEDM are not installed in Ubuntu by defalt
any more, you may have a similar issue.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
font init failed Pierrick Hanlet
Prev: font init failed Pierrick Hanlet
Next: access record info from asyn Hinko Kocevar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
