Hi Mark,
On 2012-09-10 Mark Rivers wrote:
> > Maybe camonitor should be \0-terminating the array that it gets from CA
> > too,
> Yes, I think it should. It knows it's printing a string, and it knows how
> long the array actually is, since camonitor without -S prints the correct
> values.
If you don't include the \0 then CA clients which were expecting it will break
in the way you've found camonitor -S does. I don't believe any CA client that
handles C strings will have any problem with a terminating \0 byte. Bear in
mind that before R3.14.12 CA didn't support variable length arrays at all, and
every waveform array was transported at its full NELM length, with zero values
inserted following the NORD elements of data, so older clients *had* to cope
with trailing zero bytes anyway.
> Is it documented anywhere that a
> waveform record containing a string should include the \0, and include it
> in the element count?
It was not officially documented anywhere that I know of that a waveform
record could be used to transport strings, until we added the long string
support to Base.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- caput off-by-one bug for string as array of chars J. Lewis Muir
- Re: camonitor bug for string as array of chars Andrew Johnson
- RE: camonitor bug for string as array of chars Mark Rivers
RE: How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux Guy Jennings
<2012>
Re: camonitor bug for string as array of chars Ralph Lange
<2012>
