1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: How to profile an EPICS application on Linux
To: [email protected]
Date: Mon, 10 Sep 2012 17:57:21 -0500
Hi Mark,
Lewis is right about the threading thing.  I did a Google search and came up
with an interesting article at
    http://sam.zoy.org/writings/programming/gprof.html
but that site is blacklisted by the APS firewall, so I've copied the content
from the Google cached version into the message below.  I think this approach
should work in EPICS, but I've not tried it.
- Andrew
HOWTO: using gprof with multithreaded applications
What is gprof?
gprof is the GNU Profiler, a tool used when tracking which functions are
eating CPU in your program. Anyway, you should already be familiar with it if
you got interested in this page.
One problem with gprof under certain kernels (such as Linux) is that it
doesn’t behave correctly with multithreaded applications. It actually only
profiles the main thread, which is quite useless.
Workaround
There is an easy, but surprisingly not very widespread fix for this annoying
gprof behaviour. Basically, gprof uses the internal ITIMER_PROF timer which
makes the kernel deliver a signal to the application whenever it expires. So
we just need to pass this timer data to all spawned threads.
Example
It wouldn’t be too hard to put a call to setitimer in each function spawned by
a thread, but I thought it would be more elegant to implement a wrapper for
pthread_create.
Daniel Jönsson enhanced my code so that it could be used in a preload library
without having to modify the program. It can also be very useful for libraries
that spawn threads without warning, such as libSDL. The result code is shown
below and can be downloaded (gprof-helper.c):
/* gprof-helper.c -- preload library to profile pthread-enabled programs
 * Authors: Sam Hocevar <sam at zoy dot org>
 *          Daniel Jönsson <danieljo at fagotten dot org>
 *  This program is free software; you can redistribute it and/or
 *  modify it under the terms of the Do What The Fuck You Want To
 *  Public License as published by Banlu Kemiyatorn. See
 *  http://sam.zoy.org/projects/COPYING.WTFPL for more details.
 * Compilation example:
 * gcc -shared -fPIC gprof-helper.c -o gprof-helper.so -lpthread -ldl
 * Usage example:
 * LD_PRELOAD=./gprof-helper.so your_program
#define _GNU_SOURCE
#include <sys/time.h>
#include <stdio.h>
#include <stdlib.h>
#include <dlfcn.h>
#include <pthread.h>
static void * wrapper_routine(void *);
/* Original pthread function */
static int (*pthread_create_orig)(pthread_t *__restrict,
                                  __const pthread_attr_t *__restrict,
                                  void *(*)(void *),
                                  void *__restrict) = NULL;
/* Library initialization function */
void wooinit(void) __attribute__((constructor));
void wooinit(void)
    pthread_create_orig = dlsym(RTLD_NEXT, "pthread_create");
    fprintf(stderr, "pthreads: using profiling hooks for gprof\n");
    if(pthread_create_orig == NULL)
        char *error = dlerror();
        if(error == NULL)
            error = "pthread_create is NULL";
        fprintf(stderr, "%s\n", error);
        exit(EXIT_FAILURE);
/* Our data structure passed to the wrapper */
typedef struct wrapper_s
    void * (*start_routine)(void *);
    void * arg;
    pthread_mutex_t lock;
    pthread_cond_t  wait;
    struct itimerval itimer;
} wrapper_t;
/* The wrapper function in charge for setting the itimer value */
static void * wrapper_routine(void * data)
    /* Put user data in thread-local variables */
    void * (*start_routine)(void *) = ((wrapper_t*)data)->start_routine;
    void * arg = ((wrapper_t*)data)->arg;
    /* Set the profile timer value */
    setitimer(ITIMER_PROF, &((wrapper_t*)data)->itimer, NULL);
    /* Tell the calling thread that we don't need its data anymore */
    pthread_mutex_lock(&((wrapper_t*)data)->lock);
    pthread_cond_signal(&((wrapper_t*)data)->wait);
    pthread_mutex_unlock(&((wrapper_t*)data)->lock);
    /* Call the real function */
    return start_routine(arg);
/* Our wrapper function for the real pthread_create() */
int pthread_create(pthread_t *__restrict thread,
                   __const pthread_attr_t *__restrict attr,
                   void * (*start_routine)(void *),
                   void *__restrict arg)
    wrapper_t wrapper_data;
    int i_return;
    /* Initialize the wrapper structure */
    wrapper_data.start_routine = start_routine;
    wrapper_data.arg = arg;
    getitimer(ITIMER_PROF, &wrapper_data.itimer);
    pthread_cond_init(&wrapper_data.wait, NULL);
    pthread_mutex_init(&wrapper_data.lock, NULL);
    pthread_mutex_lock(&wrapper_data.lock);
    /* The real pthread_create call */
    i_return = pthread_create_orig(thread,
                                   attr,
                                   &wrapper_routine,
                                   &wrapper_data);
    /* If the thread was successfully spawned, wait for the data
     * to be released */
    if(i_return == 0)
        pthread_cond_wait(&wrapper_data.wait, &wrapper_data.lock);
    pthread_mutex_unlock(&wrapper_data.lock);
    pthread_mutex_destroy(&wrapper_data.lock);
    pthread_cond_destroy(&wrapper_data.wait);
    return i_return;
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
How to profile an EPICS application on Linux Mark Rivers
RE: How to profile an EPICS application on Linux Mark Rivers
Re: How to profile an EPICS application on Linux J. Lewis Muir
Prev: RE: camonitor bug for string as array of chars Mark Rivers
Next: RE: How to profile an EPICS application on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: How to profile an EPICS application on Linux J. Lewis Muir
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
