1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: PIXIS-XO 100B
Date: Mon, 10 Sep 2012 12:59:40 -0700
Hi Mark,
See below.
> -----Original Message-----
> From: Mark Rivers [mailto:[email protected]]
> Sent: Monday, September 10, 2012 12:17 PM
> To: Szalata, Zenon M.
> Cc: [email protected]; Dunning, Michael
> Hi Zen,
> It's fairly complicated.  Here are the gory details as I understand them.
> The Princeton Instruments WinView program is strictly a 32-bit Windows
> application.  It exposes its functionality through the Microsoft COM interface,
> and that is how the areaDetector Roper driver controls it.
> Princeton Instruments is part of a larger company called Roper Scientific, and
> one of their sister companies is Photometrics.  Photometrics has a
> programming library called PVCAM which in principle runs on both Windows
> and Linux.  Princeton cameras can also be controlled with PVCAM.  The
> areaDetector PVCAM driver uses this library.
> Unfortunately a few years ago the Princeton and Photometrics versions of
> PVCAM diverged.   I know that the Photometrics cameras with the
> Photometrics version of PVCAM are supposed to work under Linux.  But I also
> know that the few EPICS users who have tried it have given up and gone back
> to the Windows version.  I don't think that the Princeton Instruments version of
> PVCAM works  under Linux at all, but I am not certain of this.
> Princeton has now released their own new SDK library, which they call PICAM.
> It works on 64-bits, but only Windows, not Linux.  It only works with their
> newer cameras, include the PIXIS.
> > So, not on Linux.  This may be difficult to overcome.
> Do you mean "overcome" in the sense of getting it to work on Linux
> technically, or "overcome" in the sense of a reluctance at SLAC to use
> Windows IOCs?
I guess I mean both.  On the one hand, getting this camera to work with EPICS on a Windows computer, will be somewhat of a challenge; I am not sure who will do it.  On the other hand, it seems that to get it to work under Linux is no doubt a much bigger challenge.  Well, now we know a bit more which should help deciding what to do.
Thanks Mark,
Zen
> Mark
> From: Szalata, Zenon M. [mailto:[email protected]]
> Sent: Monday, September 10, 2012 1:50 PM
> To: Mark Rivers
> Thanks Mark,
> I suspected that.  Is it limited to Windows because the vendor libraries are
> available for Windows only?  Or perhaps, it is the USB interface that forces that
> restriction.
> Zen
> Sent: Monday, September 10, 2012 11:17 AM
> Hi Zen,
> Yes, it should work with areaDetector, we are using other PIXIS USB cameras.
> They work with the Roper driver (which uses their WinView program).  They
> should also work with the PVCAM driver, which uses the Photometrics PVCAM
> library, but I don't know if anyone has tested that.  Note that the Roper driver
> only works on win32-x86, it does not work on Linux and it does not work on
> 64-bit Windows, because WinView does not run on those platforms.
> Mark
> Sent: Monday, September 10, 2012 1:08 PM
> To: Mark Rivers
> Subject: PIXIS-XO 100B
> Hi Mark,
> We are planning to purchase Princeton Instruments PIXIS-XO: 100B X-ray
> imaging camera.  It comes with USB-2 interface.  Is this device supported by
> Area Detector package?  It is the USB interface which troubles me a bit.
> Thanks,
> Zen
PIXIS-XO 100B Szalata, Zenon M.
RE: PIXIS-XO 100B Mark Rivers
RE: PIXIS-XO 100B Szalata, Zenon M.
Prev: RE: PIXIS-XO 100B Mark Rivers
Next: How to profile an EPICS application on Linux Mark Rivers
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
