1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Compilation error EPICS for RTEMS
To: [email protected]
Date: Mon, 10 Sep 2012 09:16:09 -0300
Please ignore the last message, it does not work...
Bruno Seiva Martins
On Mon, Sep 10, 2012 at 9:08 AM, Bruno Seiva Martins <[email protected]> wrote:
This problem can be solved changing the 'configure' parameters. From Norum's guide:
2. Configure RTEMS for your target architecture:
cd /usr/local/rtems-4.9.2/build
.../rtems-4.9.2/configure --target=powerpc-rtems4.9.2 \
--prefix=/usr/local/rtems/rtems-4.9.2 \
--enable-cxx --enable-rdbg --disable-tests --enable-networking \
--enable-posix --enable-rtemsbsp=mvme2100 \
If you change '--disable-tests' to '--enable-tests', apparently those missing *.rel files get created and the compilation process go on.
Bruno Seiva Martins
On Wed, Sep 5, 2012 at 8:45 AM, Bruno Seiva Martins <[email protected]> wrote:
Hi All,
I was trying to compile EPICS base for RTEMS, but the compilation process stopped with those errors:
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-dpmem.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-mp.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-part.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-signal.rel: Arquivo ou diretório não encontrado
i386-rtems4.11-g++: error: (...)/rtems-4.11/i386-rtems4.11/pc386/lib/no-rtmon.rel: Arquivo ou diretório não encontrado
The error message means "File or folder not found". I came across a thread that describes a similar problem:
But, unlike the author of the thread, I have nowhere to copy those files from. I was following Norum's guide "Getting started with EPICS on RTEMS". I built everything from source, including the toolchain for RTEMS, some libraries and RTEMS itself.
Does anyone have any idea on how to solve this?
Thanks in advance!
Best regards,
Bruno Seiva Martins
Re: Compilation error EPICS for RTEMS Eric Norum
Compilation error EPICS for RTEMS Bruno Seiva Martins
Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Prev: Re: Compilation error EPICS for RTEMS Bruno Seiva Martins
Next: Does anyone have support for Andor Neo Phillip Sorensen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Compilation error EPICS for RTEMS Eric Norum
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
