g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: EPICS build system, RELEASE file, and relative paths
To: Andrew Johnson <anj@aps.anl.gov>
Cc: tech-talk@aps.anl.gov
Date: Mon, 10 Sep 2012 12:19:19 +1000
Hi Andrew & Mark,
Thanks for the suggestions. They both look potentially very helpful.
On Fri, 7 Sep 2012 10:47:48 -0500
Andrew Johnson <anj@aps.anl.gov> wrote:
> As to your patch, it looks reasonable, but I wonder what abs_path() is doing
> that rel2abs() isn't?  Is it working around an automounter issue, or are you
> using soft links?
The issue is that rel2abs() specifically doesn't make any filesystem
checks, so does not expand /../ inside paths. ie, for a path like:
$(TOP)/../../base
Expand TOP and you might get:
/path/to/epics/modules/somemodule/../../base
The simple case is this path is equal to:
/path/to/epics/base/
... but if there's a symlink in the chain somewhere it might not, so
the only way to expand it safely is to check the
filesystem, which rel2abs can't do.
On the other hand, if the path exists (the -e check), then we can
safely call abs_path() which will collapse the /../ elements and give
us a canonical path to the actual element.
I didn't call abs_path() for non-existent files for the same reason as
the warning in the comment above EPICS::AbsPath(), which is that it
will return undef if any of the path elements before the last one are
non-existent.
(You'd think path canonicalisation would be simple, wouldn't you!)
Cheers,
Angus
> > Index: base/src/tools/EPICS/Path.pm
> > --- base/src/tools/EPICS/Path.pm        (revision 1268)
> > +++ base/src/tools/EPICS/Path.pm        (revision 1269)
> > @@ -123,6 +123,9 @@
> >      # Now calculate the absolute path
> >      my $abs = File::Spec->rel2abs($path, abs_path($cwd));
> > +    if (-e $abs) {
> > +        $abs = abs_path($abs);
> >      return LocalPath($abs);
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
Angus Gratton, Computer Control Specialist
ANU Department of Nuclear Physics
(02) 6125 2091
EPICS build system, RELEASE file, and relative paths Angus Gratton
Re: EPICS build system, RELEASE file, and relative paths Andrew Johnson
Prev: Re: Epics driver using BLT or CBLT to read FIFO wanted Michael Davidsaver
Next: Doubt regarding standards followed by EPICS manta santosh aditya santosh_aditya
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: EPICS build system, RELEASE file, and relative paths Andrew Johnson
Next: sequencer release 2.1.10 Benjamin Franksen
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
