See below
> -----Original Message-----
> From: [email protected] [mailto:tech-talk-
> [email protected]] On Behalf Of Benjamin Franksen
> Sent: Thursday, September 06, 2012 4:55 PM
> To: [email protected]
> Subject: Re: Epics driver using BLT or CBLT to read FIFO wanted
> Am Donnerstag, 6. September 2012, 21:57:00 schrieb Mark Rivers:
> > I would like to renew my plea for an update to the EPICS devLib to
> > support VME operations in an OS-independent manner. This includes
> not
> > just the DMA operations that this thread originally referenced, but
> > also basic register write and read operations.
> > For example, when Kate Feng converted my SIS320 driver from vxWorks
> to
> > RTEMS she made changes like the following:
> > - status = sysDmaFromVme(dmaId_, fifoBuffer_, (int)fifo_base_,
> > VME_AM_EXT_SUP_D64BLT, (count)*sizeof(int), 8); +#ifdef __rtems__
> > + status= BSP_VMEDmaStart(dmaId_,fifoBuffer_PCIaddr,
> > fifo_baseVMEaddr_, (count)*sizeof(int)); +#else
> > + status = sysDmaFromVme(dmaId_, fifoBuffer_,
> > + fifo_baseVMEaddr_,
> > VME_AM_EXT_SUP_D64BLT, (count)*sizeof(int), 8); +#endif
> > According to Till's message this might not have been necessary, since
> > he said he had an RTEMS implementation of Andrew's API, so perhaps
> the
> > same API call could have been used?
> > But there were also changes like this:
> > - registers_->irq_control_status_reg =
> SIS3820_IRQ_SOURCE4_DISABLE;
> > + writeReg32(®isters_->irq_control_status_reg,
> > SIS3820_IRQ_SOURCE4_DISABLE);
> > and this:
> > - firmwareVersion_ = registers_->moduleID_reg & 0x0000FFFF;
> > + firmwareVersion_ = readReg32( ®isters_->moduleID_reg) &
> > + 0x0000FFFF;
> > So where I was doing register access directly, on RTEMs this is being
> > wrapped in a function or macro. I understand that this may be needed
> > on some architectures to ensure that writes are done immediately,
> etc.
> > The problem is that Kate's code won't build on vxWorks because the
> > readReg32 function is defined in a header file only included for
> > RTEMS. I don't know of a vxWorks equivalent.
> > We really need something standard in EPICS base that we can all use
> in
> > our VME drivers to make them OS and architecture independent.
> I agree, wholeheartedly. The more so since the RTEMS way to access
> registers strikes me as the better idea anyway: matching a C struct
> definition with the register layout (as it is done traditionally in
> EPICS drivers) is error prone and non-portable, since the exact memory
> layout of a struct depends on architecture and compiler. So, yes, we
> need a set of access functions (or
> macros) like read/writeReg8/16/32 packages as an OSI library; and
> indeed devLib is the right place to put them.
There is a set of macros in devLib2 defined for all OSs
http://epics.sourceforge.net/devlib2/
They have forms like le_read32(address) and nat_write16(addr,value) with variations for 8,16, and 32 bit data widths and byte order swap (be_/le_ for PCI) and no swap (nat_ for VME). By default there are just volatile pointer dereference. There are specializations for those RTEMS and vxWorks targets which provide something better.
http://epics.sourceforge.net/devlib2/group__mmio.html
I'd provide some more links, but the hgweb page won't load for me right now...
http://epics.hg.sourceforge.net/hgweb/epics/devlib2/
Look in the common/ directory.
Michael
- RE: Epics driver using BLT or CBLT to read FIFO wanted Allison, Stephanie
- RE: Epics driver using BLT or CBLT to read FIFO wanted Mark Rivers
- Re: Epics driver using BLT or CBLT to read FIFO wanted Benjamin Franksen
- Epics driver using BLT or CBLT to read FIFO wanted Bai Jiaoni
- Re: Epics driver using BLT or CBLT to read FIFO wanted Till Straumann
quadEM R3-0 now available Mark Rivers
<2012>
<2012>
