Hi Pierrick,
If your configuration configure/* contains entries like X11_LIB=/usr/lib
then the linker will search in the wrong path on a 64 bit system.
If you want to use the same configuration files for both, 64 and 32 bit
systems, you need separate files for linux-x86 and linux-x86_64. In
configure/CONFIG_EXTENSIONS I have these lines:
include $(TOP)/configure/RELEASE
-include $(TOP)/configure/RELEASE.$(EPICS_HOST_ARCH)
This allows me to put X11_LIB=/usr/lib into RELEASE but
X11_LIB=/usr/lib64 into RELEASE.linux-x86_64
Dirk
Pierrick Hanlet wrote:
I'm using 3.14.12 on a 64-bit Scientific Linux machine. I'm attempting
to build extensions
such as edm, but always fail when the linker asks for libraries such as
libXm, etc. The
message states that it is searching for the libraries in /usr/lib, but
as a 64-bit machine,
these libraries are in /usr/lib64. I've searched tech-talk archives,
but have been unsuccessful
in finding what switch (flag) I need to set to force it to link to the
correct libraries. Would
someone kindly point me in the right direction?
Pierrick
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________
*Pierrick Hanlet*
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
- edm and other extensions on 64-bit SL machines Pierrick Hanlet
Re: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Re: caput off-by-one bug for string as array of chars Ralph Lange
<2012>
Re: edm and other extensions on 64-bit SL machines Andrew Johnson
Compilation error EPICS for RTEMS Bruno Seiva Martins
<2012>
