Hi Andrew,
This appears to be the problem.
There is nothing in the file other than the -include
$(TOP)/configure/os/CONFIG_SITE.linux-x86.linux-x86;
so it points to the the 32-bit varieties.
Thank you,
Pierrick
On 08/31/2012 05:45 PM, Andrew Johnson wrote:
Hi Pierrick,
On 2012-08-31 Pierrick Hanlet wrote:
Both edm and alh require libXm (and perhaps others of that suite). Each
fail to build with
the error:
No rule to make target `/usr/lib/libXm.a'.
This tells me that it searched and expects to find the library in
/usr/lib. If I understand things
correctly, should it not be searching in /usr/lib64 since that is where
the libraries reside?
Take a look at the file
extensions/configure/os/CONFIG_SITE.linux-x86_64.linux-x86_64
which should set those paths for you.
- Andrew
"Whether you think you can or think you can't, either way, you are
correct" -- Henry Ford
_______________________________________________________________ Pierrick Hanlet
IIT/Fermilab
+1-630-840-5555 (FNAL)
+1-312-567-5745 (IIT)
+1-630-697-8758/+44-79-48-860-197 (US/UK mobile)
