1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Mass PV assign and event flag sync [was: Creating INLINK/OUTLINK in record support]
To: [email protected]
Date: Fri, 31 Aug 2012 15:00:16 -0500
Hi Benjamin,
On 2012-08-29 Benjamin Franksen wrote:
> Though using a C99 compatible snprintf that always returns the number of
> characters it /would/ have written, had it enough space, one could easily
> avoid that. Looking at the epicsStdio.h implementation for WIN32 I see that
> the real problem here is MINGW which seems to offer no way to find out how
> large the buffer /would/ have to be (whereas Windows has _vscprintf which
> does exactly that, and VxWorks has fioFormatV).
Newer versions of the MinGW tools do now provide _vscprintf().  I'll be
deleting the MINGW-specific code from libCom/osi/os/WIN32/osdStdio.c before
the next 3.15.0.2 release, so you should soon be able to use epicsSnprint() to
find out how big a buffer you actually need.
Section 20.12 of the AppDevGuide says that the initial buffer size to find the
length needed should be non-zero since SUSv2 says systems can return an error
in that case (contrary to the C99 spec which allows it), but the manpage for
Solaris permits a size of zero with a NULL buffer, so even that might be safe
nowadays.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Creating INLINK/OUTLINK in record support Tim Mooney
Mass PV assign and event flag sync [was: Creating INLINK/OUTLINK in record support] Benjamin Franksen
Prev: RE: put to disabled records and monitors Pal Trivan
Next: edm and other extensions on 64-bit SL machines Pierrick Hanlet
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Mass PV assign and event flag sync [was: Creating INLINK/OUTLINK in record support] Benjamin Franksen
Next: Re: Creating INLINK/OUTLINK in record support Tim Mooney
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
