By following the suggestion from Jason Abernathy: I managed to get EDM working (or so it seems). I noticed that the EDM compiled with the makefile modification has six more dynamic links, namely: > ldd $EDM libXtst.so.6 => /usr/lib/x86_64-linux-gnu/libXtst.so.6 (0x00007f174e552000)
libca.so.3.14 => /opt/epics/base/lib/linux-x86_64/libca.so.3.14 (0x00007f174dfb8000) libCom.so.3.14 => /opt/epics/base/lib/linux-x86_64/libCom.so.3.14 (0x00007f174dd5f000) libreadline.so.6 => /lib/x86_64-linux-gnu/libreadline.so.6 (0x00007f174d6fb000)
librt.so.1 => /lib/x86_64-linux-gnu/librt.so.1 (0x00007f174d4f2000) libtinfo.so.5 => /lib/x86_64-linux-gnu/libtinfo.so.5 (0x00007f174ba91000) If I may ask, how did you realize that the option --no-as-needed could solve the problem? Perhaps it was noted that some important libraries weren't linked against? If so, why didn't
they get referenced in order to be included by the linker? Thank you all once again!
Best Regards, Lucas
On Sat, Aug 25, 2012 at 3:59 PM, Lucas Russo <lerwys@gmail.com> wrote: Hello Jason and John,
| ANJ, 27 Nov 2012 |
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing · |
