Hi- I know this isn't quite what you're asking for, since you
already have your huge .dbd file, but perhaps others can use it.
I wrote an awk script some years ago to help me generate dbd's for
records with potentially hundreds of fields whose names were easily
automatically generated, like for example ".[A-D][X][0-9][0-9]",
which would be (4*1*10*10)=400 fields (ie. .AX00, .AX01, .AX02,
..., .BX00, ..., all the way to .DX99).
If I recall correctly, the resulting file could be #include'd
unmodified into a top-level .dbd, but I haven't tried it lately.
See attached.
cheers,
Mike
ps- I second the nomination for SNL when run-time dynamic PV
assignment is desired.
#!/bin/sh
# 2012-08-24 updated comments [laznovsky@psi.ch]
# 2006-01-10 changed "dim" to "for" [lazmo@slac.stanford.edu]
# 2005-04-05 original [lazmo@slac.stanford.edu]
# fxplode -- combinatorial EPICS field generation
# Usage:
# fxplode inputfile > outfile
# This script accepts input blocks of the form:
# begin DBF_FLOAT
# prompt("int_coef")
# promptgroup(GUICOMMON)
# pp(TRUE)
# <... any other arbitrary field specs, e.g. interest(1), &c >
# for II IQ QI QQ
# for 0 1 2 3
# for A B C
# end
# and outputs EPICS "record field" definitions suitable for inclusion in a
# .dbd file, generating all possible combinations of the (up to 4) nested "for"s.
# The "for" values need not be single characters, but any possible combinations
# must not exceed 4 chars total (EPICS field-name limit).
# Input is processed in blocks, starting with "begin" and ending with "end" lines:
# lines starting with "begin" reset things, and save the field type
# lines starting with "for" specify one of up to 4 lists of nested substrings
# lines starting with "end" starts processing with current specs
# lines starting with "#" are ignored (and passed through)
# all other lines are saved and written out unchanged in each output field
# All input lines are also output as comments (prepended with "# ").
# The example above will output 4*4*3=48 field specs:
# field(II0A,DBF_FLOAT) {
# pp(TRUE)
# interest(1)
# field(II0B,DBF_FLOAT) { ...
# field(II0C,DBF_FLOAT) { ...
# ... all the way to:
# field(QQ3B,DBF_FLOAT) { ...
# field(QQ3C,DBF_FLOAT) { ...
# A comment is added at the end showing how many fields were generated, and if any
# duplicates were found; duplicates are listed without a "#" so they intentionally
# cause run-time load errors.
cat $* | /bin/nawk '
BEGIN {
print "#================================================"
print "#=== GENERATED FILE... do not edit!"
print "#=== fxplode v1.0"
print "#"
ntot = 0
{ # count all lines, and output as comments
lineno++
print "# " $0
/^#/ { # skip input comments
next
{ # process all others
if ($1 == "begin") {
type = $2
for (x = 0; x < 4; x++) {
din[x] = 1
dim[x 0] = ""
x = kex = 0
next
if ($1 == "for") {
din[x] = NF - 1
for (y = 0; y < NF-1; y++) {
dim[x y] = $(y+2)
if (x++ >= 4) {
print "too many \"for\"s (max 4)... line " lineno
exit
next
if ($1 == "end") {
splode()
next
if (NF > 0) extra[kex++] = $0
END { # done; check for duplicates
dup = 0
for (i = 0; i < ntot; i++) {
if (num[name[i]] > 1) {
print "*** [fxplode] *** duplicate field: " name[i] " (" num[name[i]] " times)"
dup++
print "# " ntot " fields, " dup " duplicates"
function splode()
for (i0 = 0; i0 < din[0]; i0++) {
for (i1 = 0; i1 < din[1]; i1++) {
for (i2 = 0; i2 < din[2]; i2++) {
for (i3 = 0; i3 < din[3]; i3++) {
name[ntot] = dim[0 i0] dim[1 i1] dim[2 i2] dim[3 i3]
num[name[ntot]]++
if (length(name[ntot]) > 4) {
print "*** [fxplode] *** field name too long (max 4): " name[ntot]
else {
print "\tfield(" name[ntot] "," type ") {"
for (k = 0; k < kex; k++) printf("\t\t%s\n", extra[k])
print "\t}"
ntot++
- Re: Creating INLINK/OUTLINK in record support Andrew Johnson
- RE: Creating INLINK/OUTLINK in record support Zhang, Dehong
Re: Creating INLINK/OUTLINK in record support Tim Mooney
<2012>
<2012>
