1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Motor Record 6-5-2 backlash issue?
To: Márcio Paduan Donadio <[email protected]>
Cc: [email protected]
Date: Thu, 23 Aug 2012 16:52:20 -0500
Hi Márcio,
That is the correct behavior.  Backlash is two moves, in either direction.
In one direction the target is /approached/ in a second move by the distance
set in BDST.  In the other direction, the target position is "overshot" by BDST,
and then moved back to the target.  In either direction the second move is
done with BACC and BVEL.  The idea is you can change BACC and BVEL
for this second move to be less than ACCL and VELO, thus keeping the
drive screw in contact with the stage, in a controlled way to maintain position.
In the first case you cite, your positive movement /looks/ to have no backlash
because BACC=ACCL and BVEL=VELO, making the two moves look to be one.
HTH,
Kurt
On 8/23/2012 4:25 PM, Márcio Paduan Donadio wrote:
        Hi folks.
    When BACC = ACCL and BVEL = VELO and BDST > 0, I see the movement as I expect: for positive movements, no backlash correction; for negative movements a backlash correction.
    But when BACC != ACCL or BVEL != VELO and BDST > 0, something different happens: for positive movements the motor stops before the target and moves again by BDST to hit the target.
    Is this the correct behavior?
Engenheiro de Computação - Software de Operação das Linhas de Luz
Laboratório Nacional de Luz Síncrotron – (LNLS)
Centro Nacional de Pesquisa em Energia e Materiais (CNPEM)
+ 55 (19) 3512-3520 - [email protected]
www.lnls.br
Re: Motor Record 6-5-2 backlash issue? Tim Mooney
Motor Record 6-5-2 backlash issue? Márcio Paduan Donadio
Prev: Motor Record 6-5-2 backlash issue? Márcio Paduan Donadio
Next: Re: Creating INLINK/OUTLINK in record support Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Motor Record 6-5-2 backlash issue? Tim Mooney
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
