1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: dbd file parser in 3.15 is too strict
To: [email protected]
Date: Wed, 22 Aug 2012 10:27:30 -0500
Hi Dirk,
On 2012-08-22 Dirk Zimoch wrote:
> The dbd file parser does not accept empty strings as initial values:
> Syntax error in 'initial()'
> Context: field(PORT, DBF_STRING) in recordtype(asyn) in file
> '../O.Common/streamApp.dbd'
> The field in question is:
>      field(PORT,DBF_STRING) {
>          prompt("asyn port")
>          promptgroup(GUI_INPUTS)
>          special(SPC_MOD)
>          interest(1)
>          initial("")
>          size(40)
> The problem lies in lib/perl/DBD/Parser.pm where $string does not accept
> empty strings.
Actually the problem lies in DBD/Output.pm; dbdExpand.pl was not including
quotes when writing out empty field attribute values in the expanded file.
The other DBD file parsers (in dbStaticLib and VDCT) aren't going to accept a
field attribute spelled
	initial()
either, it needs to be
	initial("")
although in practice this attribute does nothing and can be deleted since an
empty string is the default anyway.
I've just added another patch to the Known Problems page for this.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
dbd file parser in 3.15 is too strict Dirk Zimoch
Prev: Re: EPICS 3.15 generates strange shared library names Andrew Johnson
Next: Re: EPICS Base version 3.15.0.1 released Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: dbd file parser in 3.15 is too strict Dirk Zimoch
Next: EPICS2012 registration 이은희
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
