Hi all.
Has anyone here had problems with EDM rendering on Xorg x86 X servers
(Linux)? Specifically, bleed through from EDM into windows overlapping
EDM windows, and also incorrect rendering of overlapping (rectangle)
regions when using color rules to for visibility and color?
We use a method of stacking rectangles of different colors, and applying
visibility rules to expose one of the rectangles, to produce the effect
of a variable color LED. Usually there is a bottom layer rectangle with
static color and visibility, and one or more identically sized and
positioned rectangles 'above' it, with visibility rules attached to PVs.
We recently upgraded some control room consoles to SL6, and have seen
identical pages rendered differently at the same time (on different
hosts). This is with EDM running on the console, and also displaying on
the console X server. Similar and other problems have been witnessed
with other Motif applications on non-production hosts (so undocumented),
so I am suspicious that the Motif library may be part of the problem
(Open Motif). Does anyone use specific versions/configurations/packages
for Motif support?
Thanks.
Rod Nussbaumer
ISAC Controls, TRIUMF
Vancouver, Canada
Re: EPICS 3.15 generates strange shared library names Dirk Zimoch
dbd file parser in 3.15 is too strict Dirk Zimoch
<2012>
Re: EPICS 3.15 generates strange shared library names Andrew Johnson
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
