1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: OPC with binary out records
To: "Carsten Winkler" <[email protected]>
Cc: [email protected]
Date: Tue, 14 Aug 2012 14:55:34 -0700 (PDT)
Hi Carsten,
Thank you for your reply. Unfortunately when I set the DTYP to opcRaw on a
binary out record, it seems to change the value from 1 to 0 when the OPC
IOC is restarted. The RVAL changes from 1 to 4294967295. The SCAN field
for the record is Passive and PINI is set to 0.
-Patrick
> Hallo Patrick,
> the OPC specification for binary values says a zero value will be mapped
> to FALSE and all other numbers will be mapped to TRUE and stored as -1.
> If you start your OPC IOC it gets the current value from the OPC server
> for all OPC variables. The OPC server writes 0xffff for bo-records if they
> are true and so you get 65535 or -1 as integer value. If you want to get 0
> for FALSE and 1 for TRUE you should use in your boolean records (bo and
> bi) the definition field(DTYP, "opc Raw")
> Carsten
> Hi,
> I am using the OPC device support module version 3.8.0.0 to connect to an
> OPC server supplied with Beckhoff TwinCAT 2.11. This is running on Windows
> 7 Professional with Service Pack 1. For the binary out records, if they
> are set to 1, and the EPICS OPC IOC is then restarted, their value is
> changed to 65535. If they are set to 0, and the EPICS IOC is then
> restarted, they remain set to 0. I do not think I have seen this behavior
> with the binary input records.
> Thank you for your time,
> Patrick
> ________________________________
> Helmholtz-Zentrum Berlin für Materialien und Energie GmbH
> Mitglied der Hermann von Helmholtz-Gemeinschaft Deutscher
> Forschungszentren e.V.
> Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv.
> Vorsitzende Dr. Beatrix Vierkorn-Rudolph
> Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
> Sitz Berlin, AG Charlottenburg, 89 HRB 5583
> Postadresse:
> Hahn-Meitner-Platz 1
> D-14109 Berlin
> http://www.helmholtz-berlin.de
Re: OPC with binary out records Bernhard Kuner
OPC with binary out records pthomas
Re: OPC with binary out records Carsten Winkler
Prev: Re: EPICS Base version 3.15.0.1 released Tim Mooney
Next: Re: OPC with binary out records Bernhard Kuner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: OPC with binary out records Carsten Winkler
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
