g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: OPC with binary out records
To: tech-talk@aps.anl.gov
Date: Mon, 13 Aug 2012 20:02:58 -0700 (PDT)
I am using the OPC device support module version 3.8.0.0 to connect to an
OPC server supplied with Beckhoff TwinCAT 2.11. This is running on Windows
7 Professional with Service Pack 1. For the binary out records, if they
are set to 1, and the EPICS OPC IOC is then restarted, their value is
changed to 65535. If they are set to 0, and the EPICS IOC is then
restarted, they remain set to 0. I do not think I have seen this behavior
with the binary input records.
Thank you for your time,
Patrick
Re: OPC with binary out records Carsten Winkler
Prev: Re: EPICS Base version 3.15.0.1 released Kevin Peterson
Next: Re: OPC with binary out records Carsten Winkler
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Building EPICS on Mac Andrew Johnson
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
