Folks,
I'm building EPICS on Mac for the first time. I installed the XCode package, and the Command Line Tools within XCode. When I try to build EPICs base it compiles libCom fine, but then fails when linking it:
make -C O.darwin-x86 -f ../Makefile TOP=../../.. T_A=darwin-x86 install
/usr/bin/c++ -o libCom.3.14.12.dylib -dynamiclib -flat_namespace -undefined suppress -install_name /corvette/usr/local/epics/base-3.14.12.2/lib/darwin-x86/libCom.3.14.12.dylib -compatibility_version 3.14 -current_version 3.14.12 -arch i386 bucketLib.o epicsRingPointer.o epicsRingBytes.o postfix.o calcPerform.o cvtFast.o resourceLib.o epicsOnce.o epicsSingletonMutex.o dbmf.o ellLib.o envSubr.o envData.o errlog.o errSymLib.o errSymTbl.o fdmgr.o fdManager.o freeListLib.o gpHashLib.o iocsh.o registry.o libComRegister.o iocLog.o logClient.o macCore.o macEnv.o macUtil.o aToIPAddr.o adjustment.o cantProceed.o epicsConvert.o epicsExit.o epicsStdlib.o epicsString.o truncateFile.o ipAddrToAsciiAsynchronous.o epicsUnitTest.o epicsThread.o epicsMutex.o epicsEvent.o epicsTime.o epicsMessageQueue.o epicsMath.o epicsGeneralTime.o osiClockTime.o osdSock.o osdSockAddrReuse.o osiSock.o systemCallIntMech.o epicsSocketConvertErrnoToString.o osdAssert.o osdFindSymbol.o os!
dInterrupt.o osdPoolStatus.o osdSignal.o osdEnv.o epicsReadline.o epicsTempFile.o epicsStdio.o osdStdio.o osdThread.o osdMutex.o osdEvent.o osdTime.o osdProcess.o osdNetIntf.o osdMessageQueue.o devLibVME.o devLibVMEOSD.o taskwd.o epicsTimer.o timer.o timerQueue.o timerQueueActive.o timerQueueActiveMgr.o timerQueuePassive.o tsDefs.o -lreadline -lm -lgcc
ld: library not found for -lgcc
clang: error: linker command failed with exit code 1 (use -v to see invocation)
make[3]: *** [libCom.3.14.12.dylib] Error 1
make[2]: *** [install.darwin-x86] Error 2
make[1]: *** [libCom.install] Error 2
make: *** [src.install] Error 2
So it can't find the gcc library.
I'm probably doing something stupid. Am I supposed to use the XCode tools for development, or some other gcc based toolkit? Is this documented somewhere?
Also, I suspect that once that is solved I will get an error because the Mac does not come with libreadline installed?
- RE: Building EPICS on Mac Mark Rivers
Member of CLS Controls Group Elder Matias
<2012>
<2012>
