1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: Remaining free buffers in an AD plugin queue
To: Emma Shepherd <[email protected]>, "[email protected]" <[email protected]>
Date: Thu, 9 Aug 2012 04:07:18 +0000
That sounds like a good idea.  I'll try to do it for the next release.  I don't think it should be hard.
I'll also look into making available the number of buffer and memory in the pool, assuming a driver/plugin has established a limit on those.
From: [email protected] [[email protected]] on behalf of Emma Shepherd [[email protected]]
Sent: Wednesday, August 08, 2012 10:52 PM
To: [email protected]
Subject: Remaining free buffers in an AD plugin queue
Hello AreaDetector experts,
I'm wondering if there is a way to find out at runtime how many free buffers a particular plugin has left in its queue.  In our application, the file writing plugin cannot be blocking since the acquisition from the camera must not be held up, but at the same time I need to ensure that it does not drop any frames.  What we would like to be able to do is time the start of each acquisition run so that the file plugin has caught up sufficiently, but without waiting any longer than absolutely necessary.
I know there is an ArrayCounter record in both ADBase.template and NDPluginBase.template, so in theory I think the (detector.ArrayCounter - plugin.ArrayCounter) = number of used buffers, assuming they were both reset at the same point.  I guess I could put some logic in the database to check this, but to calculate how many are remaining it would have to know the queue size that was allocated to the plugin in the startup script.  I thought it would be handy if the plugin driver could expose the number of free buffers as an asyn parameter instead.
I'd be glad to hear any thoughts on this, has anyone else tried to do something similar?
Emma
Remaining free buffers in an AD plugin queue Emma Shepherd
Prev: Remaining free buffers in an AD plugin queue Emma Shepherd
Next: Re: EPICS build on armv6l Metin Aydar
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Installing MEDM on UBUNTU 10.04 LTS nalaka samarasinghe
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
