1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Base version 3.15.0.1 released
Cc: EPICS tech-talk <[email protected]>
Date: Wed, 08 Aug 2012 13:17:46 -0500
Hello Andrew,
motorRecord.cc uses dbPutLink and dbGetLink, so src/ioc/db/dbLink.h will need the usual,
#ifdef __cplusplus
extern "C" {
#endif
as src/db/dbAccessDef.h has under EPICS base 3.14.x.
Ron
On 7/31/2012 5:58 PM, Andrew Johnson wrote:
Announcing the first developer release in the Base 3.15 series, version
3.15.0.1 is now available for download and testing.  Many new features have
been incorporated into the code that have been in development since 2008 and
were contributed by users from many different sites.  Some of the changes have
not even been mentioned in the Release Notes yet, but many have.  Please read
the release notes to get some idea what's new.  Some updates were covered in
the Application Developers Guide instead (or even as well), although the
changes in that document might be a bit hard to spot.
Documentation and downloads available at
     http://www.aps.anl.gov/epics/base/R3-15/0.php
Thanks to everyone who has worked on this over the last few years (and please
consider writing some documentation for your contribution, it's not much use
it nobody knows how to use it!).
Note: This release should not be used for operational systems, it could blow
holes in your beam pipe (or insert empty beer-cans into them), quench your
superconducting magnets, or adjust all your undulator gaps to zero.  Actually
we don't guarantee that our regular releases won't do those things by mistake
either, but this release contains new code that has not been significantly
tested.
- Andrew
EPICS Base version 3.15.0.1 released Andrew Johnson
Prev: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Next: The communication between base3.14.8.2 and base3.13.8 李芳
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS Base version 3.15.0.1 released Kevin Peterson
Next: Re: EPICS Base version 3.15.0.1 released Martin Konrad
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
