| Hi,
I've downloaded the base and give a chance to run on RPi, every command i wrote was successfully run... EpicsHostArch script in startup directory gives "linux-arm" as host arch. It was hard to port other architecture files to linux-arm. It took about an hour to set up new base.
After setting up new base, i run selftest command: "make runtest". All tests passed successfully.
In addition to base module, probe, medm and visualdct extensions can be set up. They all are working properly. I just used lesstif2-dev package instead of libmotif-dev.
Regards, Metin.
--- Ankara University Institute of Accelerator Technologies Control Systems Division
Hi Florian & Tim,
On 2012-06-13 Florian Feldbauer wrote:
> worked for me too. Tim is right, you have to include
> $(CONFIG)/CONFIG.gnuCommon, too, in order
> to have the $(CC) and $(CCC) macros in the Makefiles
> defined.
Great. The gnuCommon include should go in CONFIG.linux-arm.linux-arm to match
what happens with the linux-x86 target. The CONFIG.linux-x86.linux-x86 file
also has a few settings associated with building static binaries and shared
libraries which might be needed on arm; I don't see anything in them that is
x86-specific, but I'm not sure it they're required or not.
Once we've worked out exactly what they should be I'll add these files to the
3.14 branch so they appear in the 3.14.12.3 release.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: EPICS build on armv6l Metin Aydar
Re: Cross-compilation, static build, etc Bruno Seiva Martins
Re: Cross-compilation, static build, etc Jack
<2012>
RE: EPICS build on armv6l Tim Robinson
<2012>
ANJ, 27 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
EPICSv4
IRMIS
Talk
Bugs
Documents
Links
Licensing
