Anze Zagar wrote:
Hi Andrew et al,
Congratulations on the first EPICS version > Pi release! ;-)
We made an attempt to integrate the new EPICS base into ITER's CODAC
Core System, however we did not get very far because it seems that there
is still quite some work needed to be done to EPICS modules. I haven't
spent a lot of time searching for all the problems but basically I got
stuck with asyn module which fails to compile due to some changes in
eventRecord API (i.e. it tries to assign short integer to char[40] 'val'
field of eventRecord structure).
There is some code in the asyn GPIB part that tries to access the val
field directly via a pointer and thus assumes a certain data type of
this field. The better way would be to use a DBADDR structure which
would do all necessary type conversions (like any db link is doing it).
Maybe next week I have a look into asyn. For the time being, you can
simply comment out the devGpib blocks from the asyn Makefiles (provided
you do not need davGpib support).
Dirk
- Re: EPICS Base version 3.15.0.1 released Eric Norum
- EPICS Base version 3.15.0.1 released Andrew Johnson
- Re: EPICS Base version 3.15.0.1 released Anze Zagar
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
