1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Cross-compilation, static build, etc
To: [email protected]
Date: Thu, 2 Aug 2012 13:21:30 -0500
Hi Bruno,
On 2012-08-02 Bruno Seiva Martins wrote:
> Looking closely, indeed using 'STATIC_BUILD=YES' compiled EPICS code
> statically to my executable, leaving only the shared system libraries out.
> I guess I will build a virtual machine with my target's Linux distribution
> and compile from it, although a cross compiler would be neater =)
Google does find some ways to get around this (including a Stack Overflow
question that goes into details about defining appropriately-versioned
symbols) so in theory it should be possible to do, but I suspect a VM will be
much easier in the end.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: Cross-compilation, static build, etc Bruno Seiva Martins
RE: Cross-compilation, static build, etc Mark Rivers
Prev: Re: Cross-compilation, static build, etc Bruno Seiva Martins
Next: Re: aSub INPA field and CPP attribute on win32-x86 platform Andrew Johnson
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Cross-compilation, static build, etc Bruno Seiva Martins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
