Bruno,
Good catch on the *.substitutions files.
The Make process is also responsible for copying over certain source files to IOC resource folders. "db/" holds your database and substitution files. A quick 'find' should show you more than one copy, something like:
./db/user.substitutions ./db/userHost.substitutions ./testOneApp/Db/user.substitutions ./testOneApp/Db/userHost.substitutions
So maybe the file you were editing (App/Db/) was not the one you were loading (db/).
- Mike - JLab On Tue, Jul 31, 2012 at 10:30 AM, Bruno Seiva Martins [email protected]> wrote:
Changing the st.cmd file got only two records to change:
epics> dbl
bruno.martinsHost:aiExample bruno.martinsHost:aiExample1 bruno.martinsHost:aiExample2
bruno.martinsHost:aiExample3 bruno:aSubExample bruno.martinsHost:calc1 bruno.martinsHost:calc2 bruno.martinsHost:calc3 bruno.martinsHost:calcExample
bruno.martinsHost:calcExample1
bruno.martinsHost:calcExample2 bruno.martinsHost:calcExample3 bruno.martinsHost:compressExample bruno:subExample bruno.martinsHost:xxxExample
I suspected the files user.substitutions and userHost.substitutions were the responsibles, changed "bruno.martinsHost" and "bruno.martins" to "bruno", ran st.cmd again, same results.
Only when I recompiled all changes took effect:
epics> dbl bruno:ai1 bruno:ai2 bruno:ai3 bruno:aiExample bruno:aiExample1
bruno:aiExample2 bruno:aiExample3 bruno:aSubExample bruno:calc1 bruno:calc2 bruno:calc3 bruno:calcExample bruno:calcExample1 bruno:calcExample2
bruno:calcExample3 bruno:compressExample bruno:subExample bruno:xxxExample
Is this recompilation really necessary? The way I see, the st.cmd file is a script that loads these *.substitutions files and parse them dinamically, but seems not quite like that.
On Tue, Jul 31, 2012 at 11:19 AM, Benjamin Franksen <[email protected]> wrote:
On Tuesday, July 31, 2012, Bruno Seiva Martins wrote:
> I don't know if this is the place for a begginer question, but here I go.
It is, and you are welcome.
> I'm starting out using EPICS, following basic tutorials. I was able to
> compile epics base without a problem. Then I created the example IOC
> using makeBaseApp.pl.
> Everything went fine, and I got the IOC to run:
> epics> dbl
> bruno.martinsHost:aSubExample
> bruno.martinsHost:subExample
> But then, when I tried to get more details about one of these PV's, I
> got:
> epics> dbpr bruno.martinsHost:aiExample3
> Record 'bruno.martinsHost:aiExample3' not found
> I got this message for every PV I tried, and I don't really know what
> went wrong, since the PV's are being listed...
As otehr have noted, dot ('.') is not allowed in record names.
However, your db file should have been rejected when loading, and not when
trying to find the record. So this is actually a bug in EPICS base.
Cheers
Ben
-- Bruno Seiva MartinsDepartamento de Computação Universidade Federal de São Carlos - UFSCar
- Re: Problem with the basic example Benjamin Franksen
- Problem with the basic example Bruno Seiva Martins
- Re: Problem with the basic example Bruno Seiva Martins
<2012>
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
