1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: More than 16 enumerations mbbi / mbbo
To: [email protected]
Date: Fri, 27 Jul 2012 19:50:44 +0200
Hi Hinko,
> If this record is just for displaying information to the user though you can
> make use of it;
If you only need it to display the name of the selected channel you can
also use a stringout record for each state. These stringout records can
be triggered via a set of mbbi records (each with a calc record in front
of them that picks the right input value range, e.g. 33 to 48). Only one
stringout record fires at a time. All stringout records send their data
to a single stringin which can be used to display the state with a
single record on the OPI.
Unfortunately this approach does not work for output...
Cheers
Martin
Dipl. Phys. Martin Konrad
Technische Universität Darmstadt
Institut für Kernphysik
Schlossgartenstr. 9
64289 Darmstadt
Tel.: +49-6151-16-5121
Fax: +49-6151-16-4321
More than 16 enumerations mbbi / mbbo Hinko Kocevar
Re: More than 16 enumerations mbbi / mbbo Benjamin Franksen
Re: More than 16 enumerations mbbi / mbbo Hinko Kocevar
Re: More than 16 enumerations mbbi / mbbo Andrew Johnson
Prev: EPICS and EtherChannel Shalafi
Next: Waveform read problems apwagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: More than 16 enumerations mbbi / mbbo Andrew Johnson
Next: waveform display John Dobbins
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
