Hi Gerrit,
I would not use extrainput=Ignore except when absolutely necessary,
because this may hide some errors with incomplete input strings (e.g.
because of bad connections).
Better ignore a known number of digits after your payload like
%*5c%4x%*30x
Even better do not ignore the checksum but check it. What is the
checksum algorithm? (sum of all bytes)&0xff as 2 hex digits? See the %<>
formats.
Dirk
Gerrit Kühn wrote:
On Mon, 9 Jul 2012 17:19:25 +0000 <peter.owens@stfc.ac.uk> wrote about RE:
stream device string/hex parsing:
Peter,
POAU> Have you set
POAU> extrainput = Ignore;
POAU> In your protocol file?
No, I did not recognize that this was needed, because matching %4c instead
of %4x worked fine.
But you are right, extrainput=ignore fixed the issue, also matching the
rest of the string by %s makes it work. Thanks!
POAU> Even so a better strategy would be to use redirection:
Yes, that's already on my list of improvements to try out. I just wanted
to get the "most simple" solution to work first, before trying something
more sophisticated. Anyway, thanks for the hint.
cu
Gerrit
- Re: stream device string/hex parsing Gerrit Kühn
- stream device string/hex parsing Gerrit Kühn
- RE: stream device string/hex parsing peter.owens
RE: asynPortDriver Szalata, Zenon M.
waveform display John Dobbins
<2012>
<2012>
