1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: sequencer & button click
To: Martin Konrad <[email protected]>
Cc: [email protected]
Date: Fri, 20 Jul 2012 11:57:19 -0400 (EDT)
> From: "Martin Konrad" <[email protected]>
> what's the recommended way to switch from one sequencer state to
> another
> if a button is clicked on the OPI? What type of record do you use for
> this? What does the "when" statement look like?
I'm following on Ben's recommendation of using bi/bo records.  I've found to be very flexible for later additions of "user commands" and it's easy to read/debug later.  Using bi/bo makes your GUI easy too.  Ben's example showed mbbo.  Here's using a bo for operations.
short scanBtn;   assign scanBtn to "scan";   monitor scanBtn;
short zeroBtn;   assign zeroBtn to "zero";   monitor zeroBtn;
ss ... {
  state idle {
    when (scanBtn) {
    } state makeScan
    when (abortBtn) {
        /* bogus abort, just clear the button. */
        abortBtn = 0;
        pvPut(abortBtn);
    } state idle
  state makeScan {
    when (scanBtn) {
      /* do stuff, check for abortBtn. */
      /* then make sure to reset button! */
      scanBtn = 0;
      pvPut(scanBtn);
    } state idle
Hope this might help.
Wesley
Re: sequencer & button click Martin Konrad
Prev: Re: sequencer & button click Benjamin Franksen
Next: Re: sequencer & button click Martin Konrad
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
