Hi Martin,
On 2012-07-20 Martin Konrad wrote:
> what's the recommended way to switch from one sequencer state to another
> if a button is clicked on the OPI? What type of record do you use for
> this? What does the "when" statement look like?
> P.S.: When coupling a button with some piece of hardware I usually use
> some sort of record that is scanned if the button is clicked. This
> results in a message to my device. This obviously does not work with the
> sequencer because the value of the record does not change and thus a
> monitor would not fire...
That's where you want to use an event flag that is synchronized to the monitor
updates. As Ben mentioned you may need to set MDEL to -1 on some record types
to cause monitors to always be generated. Your SNL code then looks something
like the following (not tested):
double myVar;
assign myVar to "me:myVar";
monitor myVar;
evflag myFlag;
sync myVar myFlag;
when(efTestAndClear(myFlag)) {
/* actions ... */
} next_state;
I have some vague recollection that there may have been a problem with the
efTestAndClear() function in some recent sequencer versions (Ben can
confirm/deny this), so you might need this code instead:
when(efTest(myFlag)) {
efClear(myFlag);
/* actions ... */
} next_state;
You should probably read the documentation about the syncQ statement as well,
although I don't think it is actually needed in this case.
HTH,
- Andrew
PS: Ben — the stringin and stringout records now have MPST and APST fields
which allow the user to control whether they always post monitors or only on
value change.
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: sequencer & button click Benjamin Franksen
- sequencer & button click Martin Konrad
<2012>
<2012>
