1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: asynManager isConnected
To: "'[email protected]'" <[email protected]>, "[email protected]" <[email protected]>
Date: Tue, 17 Jul 2012 12:44:04 +0000
Just to clarify one point:
>  So when another port was set up by asynPortDriver, and a new asynUser structure created, my pointer was pointing to this new structure.
asynManager maintains a pool of asynUser structures.  When pasynOctetSyncIO->disconnect(*ppasynUser) is called that asynUser structure is returned to the pool.  When pasynManager->createAsynUser is called later it does not necessarily need to create a new structure, it can allocate an existing structure from the pool if the pool is not empty.  It's a good idea to set your pasynUser pointer to NULL after calling pasynManager->freeAsynUser or pasynXXXSyncIO->disconnect(), which in turn calls pasynManager->freeAsynUser.
-----Original Message-----
Sent: Tuesday, July 17, 2012 6:39 AM
To: [email protected]
Cc: Mark Rivers
Just posting a follow up to this problem. Mark suggested some additional tests I could do to diagnose it.
The original problem was that the pasynManager->isConnected() function was saying the IP port was connected even though I initialized it with a non-valid IP address.
What was happening was that I issued a asynOctetSyncIO->connect() call on the IP port, and then attempted to set the EOS parameters, which failed because the port wasn't connected. And then I disconnected the port, like this:
status = pasynOctetSyncIO->setInputEos(*ppasynUser, inputEos, strlen(inputEos) );
if (status) {
  asynPrint(this->pasynUserSelf, ASYN_TRACE_ERROR,
	      "drvPmacCreate: unable to set input EOS on %s: %s\n",
	      port, (*ppasynUser)->errorMessage);
  pasynOctetSyncIO->disconnect(*ppasynUser);
  return status;
So, the asynUser structure was freed by asynManager. However, my pointer to it was still valid. So when another port was set up by asynPortDriver, and a new asynUser structure created, my pointer was pointing to this new structure. And since this new structure was connected ok, asynManager->isConnected() returned true.
Cheers,
Matt
> From: Mark Rivers [mailto:[email protected]]
> Sent: 02 June 2012 17:54
> To: J. Lewis Muir; Pearson, Matthew (DLSLtd,RAL,DIA)
> Cc: [email protected]
> > I don't know of a function in Asyn that allows one to determine
> > whether the IP socket is connected.  I always just determine
> > this based on the asynStatus returned from a read or write.  But
> > maybe there's a way that I don't know about?
> pasynManager->isConnected() will tell you this.
> It will return 1 when the underlying driver has most recently called
> pasynManager->exceptionConnect().  It will return 0 when the underlying
> driver has most recently called pasynManager->exceptionDisconnect().
> Note that it can take some time after an IP device is disconnected
> (network cable unplugged etc.) before the drvAsynIPPortDriver can
> determine that the device is disconnected and calls pasynManager-
> >exceptionDisconnect().  During this time the client will receive
> timeout messages, rather than disconnected messages.
> To illustrate this, I have run the test program I posted in my last
> message with a 4'th case: the IP device is initially available, and
> then reboots, and becomes available again:
> 2012/06/02 11:47:40.425 testConnect:pollerTask: numWrite=26, wrote:
> FirmwareVersionGet(char *), numRead=60, response=0,XPS-Q8 Firmware
> Precision Platform V1.0.0 Beta 27,EndOfAPI
> 2012/06/02 11:47:41.426 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:42.426 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:43.427 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:44.427 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:45.428 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:46.429 testConnect:pollerTask: error calling
> pasynOctetSyncIO->writeRead, status=1, error=newport-xps5:5001 timeout:
> Resource temporarily unavailable
> 2012/06/02 11:47:47.429 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:48.430 testConnect:pollerTask: error calling
> 2012/06/02 11:47:49.430 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:50.431 testConnect:pollerTask: error calling
> 2012/06/02 11:47:51.431 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:52.432 testConnect:pollerTask: error calling
> 2012/06/02 11:47:53.432 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:54.433 testConnect:pollerTask: error calling
> 2012/06/02 11:47:55.433 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:56.434 testConnect:pollerTask: error calling
> 2012/06/02 11:47:57.434 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:47:58.177 testConnect:pollerTask: error calling
> pasynOctetSyncIO->writeRead, status=3, error=newport-xps5:5001 read
> error: Connection reset by peer
> 2012/06/02 11:47:59.177 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:48:00.178 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:48:01.179 testConnect:pollerTask: isConnected = 1
> 2012/06/02 11:48:02.179 testConnect:pollerTask: isConnected = 1
> Note that initially the device is connected, isConnected=1 and the I/O
> succeeds.  Then the device is rebooted.  For the next 10 seconds or so
> isConnected is still 1, but the I/O returns a timeout error and the
> error "Resource temporarily unavailable".  Then the device reconnects
> and things proceed normally.  If the device had remained off-line for
> longer eventually the IP driver would have detected that the device was
> not available and called pasynManager->exceptionDisconnect().  At that
> time isConnected would have been 0.
> Mark
> Mark
> From: [email protected] [[email protected]] on
> behalf of J. Lewis Muir [[email protected]]
> Sent: Friday, June 01, 2012 10:18 AM
> Subject: Re: asynManager isConnected
> On 6/1/12 6:17 AM, [email protected] wrote:
> > Hi,
> > I'm trying to use asynManager isConnected() to test whether or not an
> IP port is connected to a device. But I'm finding that isConnected()
> only seems to report the connected status of the asynUser structure to
> the underlying device.
> > If I attempt to call drvAsynIPPort on an IP address that has nothing
> connected to it, the connection fails. Then I attempt to connect an
> asynUser to this port using asynOctetSyncIO connect(), which also
> fails. Then I call asynManager isConnected a few times, and I find that
> the first few calls return false, and then after iocInit it returns
> true. But still, in the background, asynManager is attempting to
> connect to the IP port via the autoConnect feature.
> > Is this behaviour correct?
> > I can get around it by maintaining connected status myself. But the
> documentation seems to indicate that isConnected() shouldn't return
> true if the IP port is not connected.
> Hi, Matt.
> I'm sure Mark Rivers or someone else will give a more helpful
> response, but I'll just share what I usually do.
> If I want to write an IP client that handles connecting and
> disconnecting of an IP socket, I do the following:
> 1. Ensure that auto-connect is disabled for the ASYN IP port
> 2. Create and attach an asynUser to the ASYN port using
>    pasynOctetSyncIO->connect
> 3. Create and attach an asynUser for the pasynCommonSyncIO
>    interface using pasynCommonSyncIO->connect
> 4. Establish the IP socket connection (using the
>    pasynCommonSyncIO asynUser) using
>    pasynCommonSyncIO->connectDevice
> 5. I can now use the pasynOctetSyncIO asynUser for reading and
>    writing on the IP socket.
> If I don't want to handle connecting and disconnecting of an IP
> socket myself, I enable auto-connect for the ASYN port and don't
> make any attempt at connecting or disconnecting the IP socket
> since that would interfere with the auto-connect functionality.
> Lewis
asynManager isConnected matthew.pearson
Re: asynManager isConnected J. Lewis Muir
RE: asynManager isConnected Mark Rivers
RE: asynManager isConnected matthew.pearson
Prev: RE: asynManager isConnected matthew.pearson
Next: Re: Problems when download synApps IOC Tim Mooney
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: mbbi/mbbo Mask values Dudley, David
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
