I just installed a new OMS MAXv VME card and was getting an error when calling MAXvConfig() in st.cmd :
MAXvSetup(1, 16, 0xF000, 200, 5, 10)
0x00000000 (0)
#config0="AX LH PSO"
MAXvConfig(0, "AX LH PSO", 0x00)
Cexp syntax error: syntax error, unexpected '(', expecting '=' or '\n'
Passing 2 parameters returned the same error :
0x00000000 (0)
MAXvConfig(0, "AX LH PSO")
It looks like MAXvConfig() expects three parameters in the rest of the code, but it's function definition only defines 2 in drvMAXv.cc.
I recompiled with the small change and no longer get the error. However, I'm just setting everything up first the first time and don't yet have a motor connected so am not sure if this is the correct fix. Could anyone with more experience provide more insight?
All jumpers are default factory settings except for J13.
Jumper J13 is set for A16 supervisory access (0x2D or 101101)
Original drvMAXv.cc:
/* Common local function declarations. */
extern "C" {
RTN_STATUS MAXvSetup(int, int, unsigned int, unsigned int, int, int);
RTN_VALUES MAXvConfig(int, const char *);
Modified drvMAXv.cc:
extern "C" {
RTN_VALUES MAXvConfig(int, const char *, int);
Nia Only in MAIN_TRUNK-nia/motorApp/OmsSrc: .svn
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/CVS and MAIN_TRUNK-nia/motorApp/OmsSrc/CVS
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.Common and MAIN_TRUNK-nia/motorApp/OmsSrc/O.Common
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.RTEMS-beatnik and MAIN_TRUNK-nia/motorApp/OmsSrc/O.RTEMS-beatnik
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.RTEMS-mvme3100 and MAIN_TRUNK-nia/motorApp/OmsSrc/O.RTEMS-mvme3100
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.RTEMS-uC5282 and MAIN_TRUNK-nia/motorApp/OmsSrc/O.RTEMS-uC5282
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.linux-x86 and MAIN_TRUNK-nia/motorApp/OmsSrc/O.linux-x86
Only in MAIN_TRUNK-nia/motorApp/OmsSrc: O.linuxRT-x86
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.vxWorks-mpc8540 and MAIN_TRUNK-nia/motorApp/OmsSrc/O.vxWorks-mpc8540
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.vxWorks-ppc604_altivec and MAIN_TRUNK-nia/motorApp/OmsSrc/O.vxWorks-ppc604_altivec
Common subdirectories: motor-R6-7-RC5_1-2/motorApp/OmsSrc/O.vxWorks-ppc604_long and MAIN_TRUNK-nia/motorApp/OmsSrc/O.vxWorks-ppc604_long
diff motor-R6-7-RC5_1-2/motorApp/OmsSrc/drvMAXv.cc MAIN_TRUNK-nia/motorApp/OmsSrc/drvMAXv.cc
181c181
< RTN_VALUES MAXvConfig(int, const char *);
Only in MAIN_TRUNK-nia/motorApp/OmsSrc: drvMAXv.cc~
- RE: MAXvConfig() error in st.cmd Mark Rivers
Re: Support Required for SNL Kasemir, Kay
Re: Support Required for SNL Benjamin Franksen
<2012>
Re: Support Required for SNL J. Lewis Muir
<2012>
