1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EDM Segmentation fault
To: <[email protected]>
Date: Thu, 12 Jul 2012 16:29:54 +0200
On Thursday, July 12, 2012, Benjamin Franksen wrote:
> On Thursday, July 12, 2012, Zhang Yuliang wrote:
> > Hello all,
> > I am trying to install EDM-1-12-78 on a Redhat 4.8 32 bit machine and
> > am able to build it successfully. However, when I try to create a new
> > edl file or open an existing edl file , the EDM crashes with the error
> > of "Segmentation fault".
> > How to solve this issue?
> The very first thing is to inlcude the author (John William Sinclair
> <[email protected]>), as I believe he does not listen to tech-talk for
> bug reports.
> Then, make sure a core file gets generated. If not, enable this by
> issuing the command
> > ulimit -c unlimited
> on the shell before starting edm. Now, load edm (the executable) into a
> debugger (I use ddd as frontend to gdb), let it crash, load the core
> file, ask ddd to let you see the stack backtrace. Post this backtrace.
Sorry, this is confusing, what I meant to say:
1) start edm
2) let it crash
3) load edm (executable) into ddd
4) load core file
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
EDM Segmentation fault Zhang Yuliang
Re: EDM Segmentation fault Benjamin Franksen
Prev: Re: EDM Segmentation fault Benjamin Franksen
Next: Re: EDM Segmentation fault John William Sinclair
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
