1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problem in seq-2.1.8
To: [email protected]
Date: Tue, 10 Jul 2012 13:08:26 -0500
Hi Ben,
On 2012-07-10 Benjamin Franksen wrote:
> I intended the '#' character to be a comment for make, not for the shell.
In future releases of Base you can use $(NOP) as a command that does nothing,
but that only got added to the build files after 3.14.12.2 came out.  You can
use
	$(PERL) -e ''
on all platforms to do nothing (NOP is defined as : on non-windows systems
since that's faster).
HTH,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Problem in SNL santosh aditya
Re: Problem in seq-2.1.8 Benjamin Franksen
Prev: Re: Problem in seq-2.1.8 Benjamin Franksen
Next: Module for Labtech H150-1000 chiller Alan Greer
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: stream device string/hex parsing Gerrit Kühn
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
