On Mon, 9 Jul 2012 17:19:25 +0000 <[email protected]> wrote about RE:
stream device string/hex parsing:
Peter,
POAU> Have you set
POAU> extrainput = Ignore;
POAU> In your protocol file?
No, I did not recognize that this was needed, because matching %4c instead
of %4x worked fine.
But you are right, extrainput=ignore fixed the issue, also matching the
rest of the string by %s makes it work. Thanks!
POAU> Even so a better strategy would be to use redirection:
Yes, that's already on my list of improvements to try out. I just wanted
to get the "most simple" solution to work first, before trying something
more sophisticated. Anyway, thanks for the hint.
cu
Gerrit
- Re: stream device string/hex parsing Dirk Zimoch
- stream device string/hex parsing Gerrit Kühn
- RE: stream device string/hex parsing peter.owens
New version of LabVIEW-EPICS-interface CA Lab Carsten Winkler
Re: Problem in seq-2.1.8 Benjamin Franksen
<2012>
<2012>
