1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Problems with parallel make on seq-2-1-7
Date: Fri, 6 Jul 2012 14:33:04 +0200
On Friday, July 06, 2012, Mark Rivers wrote:
> I believe this is the same problem which we've experienced, but now
> fixed, in every synApps module that defines a new record.
> The .dbd files must be processed to generate the .h files.  When running
> without parallel make things worked fine with the existing src/Makefile
> rules.  However, when running parallel make it would occasionally fail
> because it tries to compile the record.c file before the record.h file
> exists.
> This is the change I made earlier this week in
> synApps/vme/vmeApp/src/Makefile:
> corvette:vme/vmeApp/src>svn diff -rPREV Makefile
> Index: Makefile
> --- Makefile    (revision 14860)
> +++ Makefile    (working copy)
> @@ -62,3 +62,6 @@
>  #  ADD RULES AFTER THIS LINE
> +# Parallel build sometimes fails.
> +# Make dependences on epidRecord.h explicit.
> +vmeRecord$(OBJ):          $(COMMON_DIR)/vmeRecord.h
> Once I added such lines to all Makefiles in synApps modules that build
> new record types then a parallel make of synApps has never failed.
> The problem we are seeing with seq looks the same.
Exactly. This time the problem is in RULES.Db:
$(COMMON_DIR)/%Record.h: $(COMMON_DIR)/%Record.dbd
	@$(RM) $(notdir $@)$(DEP)
	@$(DBDDEPENDS_CMD)
	echo "$< : ../Makefile" >> $(notdir $@)$(DEP)
	@$(RM) $(notdir $@)
	$(DBTORECORDTYPEH) $(DBDFLAGS) $< $(notdir $@)
	@$(MV) $(notdir $@) $@
(and five other similar rules in the same file). This would be correct:
$(COMMON_DIR)/%Record.h$(DEP): $(COMMON_DIR)/%Record.dbd
	@$(RM) $@
	$(MKMF) -m $@ $(DBDDEPENDS_FLAGS) $*Record$(OBJ) $<
	echo "$< : ../Makefile" >> $@
	@$(RM) $@
	$(DBTORECORDTYPEH) $(DBDFLAGS) $< $@
BTW, the new rule I proposed for .d generation needs an adapted definition
of HDEPENDSFLAGS in CONFIG_COMMON to work, i.e. instead of
HDEPENDSFLAGS = -m $*$(DEP) $(HDEPENDS_INCLUDES) $@ $<
we should have
HDEPENDSFLAGS = -m $@ $(HDEPENDS_INCLUDES) $*$(OBJ) $<
Cheers
Ben
> Mark
> From: Benjamin Franksen [[email protected]]
> Sent: Friday, July 06, 2012 5:59 AM
> To: Mark Rivers; [email protected]
> Hi Mark
> I add tech-talk to the list since this is a problem in the EPICS base
> rules.
> On Friday, July 06, 2012, you wrote:
> > With the old version it failed about 1 in 10 times at most.
> > With the new version there is a more serious problem.  It fails even
> > without a parallel make!
> > I did a parallel make on the clean and uninstall, but then a
> > non-parallel make on the build:
> > corvette:~/devel/seq>make -sj uninstall
> > mkdir ../../../include
> > mkdir ../../../lib/linux-x86
> > mkdir ../../../lib/vxWorks-68040
> > mkdir ../../../bin/vxWorks-68040
> > mkdir ../../../lib/vxWorks-ppc603_long
> > mkdir ../../../bin/vxWorks-ppc603_long
> > mkdir ../../../lib/vxWorks-ppc604_long
> > mkdir ../../../bin/vxWorks-ppc604_long
> > mkdir ../../../bin/linux-x86
> > mkdir ../../../dbd
> > ../snl.re:16:17: fatal error: snl.h: No such file or directory
> > compilation terminated.
> > make[3]: *** [lexer.o] Error 1
> > make[2]: *** [install.linux-x86] Error 2
> > make[1]: *** [snc.install] Error 2
> > make: *** [src.install] Error 2
> > If I do a parallel make on the build it actually works most if not all
> > of the time, but a non-parallel make fails.  This seems strange.
> I tried this on another comupter that runs a fedora linux today and I
> could reproduce this. The make version is 3.82 (on my system it is 3.81)
> and this is probably the same version you have.
> After the failed make (without -j) search for lexer.d; you won't find it.
> That means there is no dependency of lexer.o on snl.h and thus it does
> not get created before trying to compile lexer.c. If you add snl.h
> explicitly to the prerequisites of lexer.o
> lexer.o: snl.h
> Then the build works fine. However, this dependency should have been
> generated automatically, there should be a file lexer.d that lists all
> the dependencies of lexer.o on all the header files lexer.c includes.
> The parallel build works because the rules that generates snl.c and snl.h
> is executed in parallel and therefore in this case the snl.h
> (accidentally) exists. This is a excerpt of the relevanmt rules in the
> sequencer's Makefile (the fixed version, not the one in 2.1.7):
> snl.c: snl.lem snl.lt $(LEMON)
>         $(RM) snl.c snl.h
>         $(LEMON) o=. $< # this command creates snl.c and snl.h
> snl.h: snl.c
>         # empty recipy needed to work around make bug #35455
> vpath %.re ..
> lexer.c: snl.re
>         $(RE2C) -s -b -o $@ $<
> These rules are fine. What's wrong is teh rules in base that build the
> dependency files (.d). The following is from RULES_BUILD:
> %$(OBJ): %.c
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
>         $(COMPILE.c) $(call PATH_FILTER,$<) $(COMPILE_FILTER.c)
> %$(OBJ): %.cc
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
>         $(COMPILE.cpp) $(call PATH_FILTER,$<) $(COMPILE_FILTER.cpp)
> %$(OBJ): %.cpp
>         @$(HDEPENDS_CMD)
>         @$(RM) $@
> This means .d files are not generated before the rules to compile a .c
> file fires. Instead they are generated together with the object files.
> This is bad, since it means that the header files must all exist or be
> explicitly added as dependencies.
> Instead, there should explicit rules that generate .d from .c:
> %$(DEP): %.c
>         @$(HDEPENDS_CMD)
> and similar for .cc and .cpp. When I add such a rule to the Makefile,
> everything build just fine on the fedora system with make 3.82. The
> $(HDEPENDS_CMD) can then be removed from the object generation rules.
> There remains the question what do about this problem? Should I add the
> extra dependency (lexer.o: snl.h) to the Makefile? Or should I add the
> missing rules for .d files?
> Cheers
> Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
Re: Problems with parallel make on seq-2-1-7 Benjamin Franksen
RE: Problems with parallel make on seq-2-1-7 Mark Rivers
Prev: RE: Problems with parallel make on seq-2-1-7 Mark Rivers
Next: sequencer release 2.1.8 Benjamin Franksen
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Problems with parallel make on seq-2-1-7 Andrew Johnson
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
