On 2012-07-04 haquin wrote:
> Will this modification be integrated in the next EPICS release ? when ?
Thanks to your reminder I have implemented this on the 3.15 branch. However
the 3.15.0.x releases which we're currently working on are not intended for
operational use, and at this stage I can't predict when the first operational
release 3.15.1 will be out -- sorry!
On 2012-07-04 [email protected] wrote:
> I'm pretty sure it's always safe to strtoul(), the behaviour in the
> presence of a minus sign seems well defined in the man page I'm reading
> and I've certainly not encountered problems using it.
You're right, and since the conversation on this topic I read up on this and
have added a set of fully tested APIs to libCom in the 3.15 branch for parsing
ASCII numbers into the various epicsInt* and epicsUInt* types, testing for
overflows in all cases.
Literals that start 0x or 0X will be parsed by epicsCalc as an epicsUInt32.
Other literals will be parsed using epicsStrtod() as before. That means it
will not be possible to use hex floating-point literals in 3.15, although they
may have worked in earlier releases on platforms where strtod() supports them.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
- Re: mask for bitwise operation in CALC record haquin
- mask for bitwise operation in CALC record haquin
- RE: mask for bitwise operation in CALC record michael.abbott
Re: caQtDM: a MEDM replacement Michael Johnson
Re: 回复: Re: Re: Problems when download synApps IOC Tim Mooney
<2012>
<2012>
