Hello,
Consider a client that subscribes for two PVs (here in particular two
fields of the same record). Now the IOC (the record support) posts
events on both fields. Is the time order of these two events preserved?
In other words, are the monitor callbacks of the client called in the
same order as the IOC calls db_post_events()?
In my particular case, I have a client (with unknown source code) that
sometimes sees value changes on two fields of the motor record, DMOV and
RRBV, in the wrong order. Thus in the DMOV callback, RRBV still has the
old value. I checked in the motor record that DMOV is always posted
after RRBV.
Is there any mechanism in EPICS that could swap the execution order or
should the problem be searched in the client?
Dirk
- Re: Question about CA event (i.e. monitor) time order Andrew Johnson
- Re: Question about CA event (i.e. monitor) time order Tim Mooney
Re: 回复: Re: Re: Problems when download synApps IOC Dirk Zimoch
Re: caQtDM: a MEDM replacement Michael Johnson
<2012>
Re: ImageJ from waveform record Steve Kinder
<2012>
ANJ, 18 Nov 2013 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
