1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: iptables example script for EPICS CA
Cc: Edward Sternin <[email protected]>
Date: Fri, 29 Jun 2012 12:32:21 +0000
Folks,
I am trying to help someone who is new to EPICS get it running on a Linux host that needs to run the iptables firewall.  He needs to run both a soft IOC and EPICS clients on this machine.  He's having trouble configuring the iptables firewall correctlly.  If he disables iptables things work fine, but with it enabled EPICS does not work.
Can someone send an example of an iptables script that allows CA to run on the default ports of 5064 and 5065, UDP and TCP?
Re: iptables example script for EPICS CA John William Sinclair
Prev: RE: LabVIEW EPICS connection ulrik.pedersen
Next: Re: SynApps build error : win32-x86 Brands Helge
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: ethernet-based Gamma ion pump controller (mpc) Scott Baily
Next: Re: iptables example script for EPICS CA John William Sinclair
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
