Hi Zen,
If you don't see the printf message in the console output then something is wrong.
My IpUnidig driver does exactly the same thing your driver does: register a C-linkage callback function with epicsAtExit, which in turn calls a C++ class member function. I just added a printf to the C++ member function, and it does print the message when I type "reboot" at the vxWorks prompt.
void IpUnidig::rebootCallback()
ipUnidigRegisters r = regs_;
printf("IpUnidig::rebootCallback, disabling interrupts\n");
fflush(stdout);
epicsThreadSleep(0.5);
*r.intEnableRegisterLow = 0;
*r.intEnableRegisterHigh = 0;
rebooting_ = 1;
ioc13lab> reboot
Note that until I added the epicsThreadSleep(0.5) my printf message was truncated, and it is possible you would not see it at all in spite of the fflush(). Try adding the epicsThreadSleep() to make sure the printf message is indeed not being printed.
-----Original Message-----
From: Szalata, Zenon M. [mailto:zms@slac.stanford.edu]
Sent: Thursday, June 28, 2012 11:10 AM
To: Mark Rivers; Williams Jr., Ernest L.
Cc: tech-talk@aps.anl.gov
Subject: RE: epicsAtExit
Hi Mark,
I don't see the printf message in the console output. I see no evidence that rebootCB() is called.
This is how I have implemented the _wtReg function:
asynStatus drvV792::_wtReg( uint off,word v){
// Reads a register at off offset wrt base and returns the read value in v.
volatile word* padr=(word*)(_pmem+off);
if(!_pmem) return(asynError);
*padr=v;
//printf( "%s::_wtReg: off=0x%x, v=%d\n",dname,off,v);
return(asynSuccess);
I will try the read after write in rebootCB().
Thank you Mark,
Zen
> From: Mark Rivers [mailto:rivers@cars.uchicago.edu]
> Sent: Wednesday, June 27, 2012 9:01 PM
> To: Szalata, Zenon M.; Williams Jr., Ernest L.
> Hi Zen,
> With the asyn driver do you see the printf message, i.e. is the
> drvV792::rebootCb() function being called?
> Perhaps the VME writes to disable interrupts are not actually being done
> because they are cached, and the cache is never flushed before the system
> shuts down. Have you declared ILEV and EVTR to be volatile? What happens if
> you do a read from those registers after the writes, which should flush the
> cache?
> Mark
> ________________________________
> From: Szalata, Zenon M. [zms@slac.stanford.edu]
> Sent: Wednesday, June 27, 2012 7:40 PM
> Subject: epicsAtExit
> Hi Mark,
> I have a problem, which I have been ignoring for a while.
> I have a device driver for a VME module based on asynPortDriver class. It is
> used with asyn R4.18, EPICS R3.14.12.2, vxWorks 6.6.
> I have coded a couple of routines to disable interrupts when the IOC is
> shutdown (with CTRL-X), which does not work. Restarting the IOC which uses
> the asyn based driver with CTRL-X fails to come up. The IOC reaches some
> point in the booting sequence and then I suppose it crashes because the boot
> starts all over. I recover from that with a VME reset. Also, if I disable interrupts
> before rebooting all works fine.
> I have created another device driver using the conventional approach, which
> does not use asyn. As far as I can tell most of the code if not the same is
> equivalent. With this device driver the interrupts get disabled on exit.
> This is what I have in the asynPortDriver version of the device driver:
> In the constructor I have:
> epicsAtExit( rebootCbC,this);
> then I have:
> extern "C"{
> static void rebootCbC( void* pvt){
> drvV792* pthis=(drvV792*)pvt;
> pthis->rebootCb();
> void drvV792::rebootCb(){
> printf( "%s::rebootCb: Interrupts disabled and Soft reset\n",dname);
> fflush(stdout);
> epicsThreadSleep(1.0);
> _wtReg( ILEV,0);
> _wtReg( EVTR,0);
> Writing 0 to the EVTR disables interrupts. Also writing 0 to the ILEV register
> In fact, the same rebootCB code, seems to work fine in the non-asyn driver.
> Is something subtle taking place because of vxWorks?
> Can you offer suggestion on how to make it work?
> Thanks in advance,
> Zen
- RE: epicsAtExit Szalata, Zenon M.
- epicsAtExit Szalata, Zenon M.
- RE: epicsAtExit Mark Rivers
Re: epicsAtExit Andrew Johnson
<2012>
<2012>
