1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: SynApps build error : win32-x86
Date: Tue, 26 Jun 2012 17:04:33 -0500
Hi Andrew,
I have successfully built synApps using strawberry perl and gmake and MSVS 2008.
EPICS_HOST_ARCH=win32-x86
Jeff
On 6/26/2012 4:29 PM, Andrew Johnson wrote:
Hi Mark,
On 2012-06-26 Mark Rivers wrote:
The tools are called dmake and gmake.  How are those conflicting, or is it
something else in that folder?
When Josh runs "make" somehow it's not running the the same version of make
that 'where' displays, and it doesn't sound like it's running either gmake or
dmake from Strawberry Perl.  I don't know whether his 'where' tool is lying to
him, that seems a distinct possibility.
For future reference, I have just successfully built Base using just the tools
(Perl, gmake, gcc, g++) that come with Strawberry Perl 5.14.2.1-32bit, with
EPICS_HOST_ARCH set to win32-x86-mingw.  The result passes all of the built-in
test programs.  Josh is building SynApps though, which I haven't checked.
- Andrew
Jeffrey Gebhardt
Beamline Controls and Data Acquisition
APS Engineering Support Division
630-252-5026
Re: SynApps build error : win32-x86 S. Stein
Re: SynApps build error : win32-x86 Andrew Johnson
RE: SynApps build error : win32-x86 Mark Rivers
Prev: Re: SynApps build error : win32-x86 Andrew Johnson
Next: Access to Gpib Address via record in ASYN Andrew Wagner
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: SynApps build error : win32-x86 Jeffrey Gebhardt
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
