1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: SynApps build error : win32-x86
To: "'[email protected]'" <[email protected]>
Date: Tue, 26 Jun 2012 19:05:46 +0000
What executables are in the Strawerry perl directory?
I've always used Active perl whose bin directory contains only the following:
C:\EPICS>
C:\EPICS>dir c:\Perl64\bin\*.exe
 Volume in drive C is OS
 Volume Serial Number is 980C-2AE9
 Directory of c:\Perl64\bin
10/07/2011  04:58 PM           123,904 a2p.exe
10/07/2011  04:57 PM           380,416 perl.exe
10/07/2011  04:57 PM           380,416 perl5.14.2.exe
10/07/2011  04:14 PM             5,120 perlglob.exe
10/07/2011  04:57 PM           380,416 wperl.exe
               5 File(s)      1,270,272 bytes
               0 Dir(s)  389,777,080,320 bytes free
-----Original Message-----
Sent: Tuesday, June 26, 2012 1:39 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re: SynApps build error : win32-x86
Jeff, Mark, all:
  It appears Jeff may have found the smoking gun; unfortunately I don't really understand why. I moved the path to Strawberry perl to the end of my $PATH$ environment variable and things built just fine.
  If anyone can illuminate me as to what was going on, I would be ecstatic.
--josh
----- Original Message -----
To: "Mark Rivers" <[email protected]>
Sent: Tuesday, June 26, 2012 10:59:23 AM
It is the details of "make" which cause me much head-scratching...
Here are details on my version of make:
C:\synApps_5_6\support>where make
C:\Program Files (x86)\GnuWin32\bin\make.exe
C:\synApps_5_6\support>make --version
GNU Make 3.81
Copyright (C) 2006  Free Software Foundation, Inc.
This is free software; see the source for copying conditions.
There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A
PARTICULAR PURPOSE.
This program built for i386-pc-mingw32
To: "S. Stein" <[email protected]>
Cc: [email protected], "Jeffrey Gebhardt" <[email protected]>
Sent: Tuesday, June 26, 2012 10:55:27 AM
OK, so what is different when the command is executed  by "make" versus doing it interactively?
Are you sure you are running the GnuWin32 version of make?  That's what I am using.  Can you send the output of "make --version".
Sent: Tuesday, June 26, 2012 12:13 PM
To: Mark Rivers
Cc: [email protected]; Jeffrey Gebhardt
I had done this before and it worked without error - to verify, I just did it again with identical results as yours Mark:
C:\synApps_5_6\support\seq-2-1-3\src\snc\O.win32-x86>dir ..\O.Common
 Volume Serial Number is 0E2D-6055
 Directory of C:\synApps_5_6\support\seq-2-1-3\src\snc\O.Common
06/26/2012  10:09 AM    <DIR>          .
06/26/2012  10:09 AM    <DIR>          ..
               0 File(s)              0 bytes
               2 Dir(s)  112,097,034,240 bytes free
C:\synApps_5_6\support\seq-2-1-3\src\snc\O.win32-x86>..\\..\\..\\bin\\win32-x86\
\lemon.exe o=. -g ../snl.lem > ../O.Common/snl.bnf.tmp
06/26/2012  10:10 AM    <DIR>          .
06/26/2012  10:10 AM    <DIR>          ..
06/26/2012  10:10 AM             8,708 snl.bnf.tmp
               1 File(s)          8,708 bytes
               2 Dir(s)  112,097,021,952 bytes free
To: "S. Stein" <[email protected]>, "Jeffrey Gebhardt" <[email protected]>
Sent: Tuesday, June 26, 2012 9:48:52 AM
Hi Josh,
I don't think that is from a previous portion of the build.
Please try just manually entering that command using cut and paste.  I just did that on my system.  I did a cd to the seq-2-1-7\src\snc\O.win32-x86 directory and then manually executed the "lemon.exe" command, using cut-and-paste from my build screen.   First deleted the snl.bnf.tmp file to make sure the command actually worked.
It worked fine, no error.
J:\epics\devel\seq-2-1-7\src\snc\O.win32-x86>del ..\O.Common\snl.bnf.tmp
J:\epics\devel\seq-2-1-7\src\snc\O.win32-x86>dir ..\O.Common\
 Volume in drive J is people_rw
 Volume Serial Number is 1FC2-CD09
 Directory of J:\epics\devel\seq-2-1-7\src\snc\O.Common
06/26/2012  11:46 AM    <DIR>          .
06/26/2012  09:44 AM    <DIR>          ..
06/26/2012  09:45 AM             5,556 bnf.inc
               1 File(s)          5,556 bytes
               2 Dir(s)  645,751,332,864 bytes free
J:\epics\devel\seq-2-1-7\src\snc\O.win32-x86>..\\..\\..\\bin\\win32-x86\\lemon.exe o=. -g ../snl.lem > ../O.Common/snl.bnf.tmp
06/26/2012  11:47 AM             8,708 snl.bnf.tmp
               2 File(s)         14,264 bytes
               2 Dir(s)  645,751,316,480 bytes free
If you get an error then there is something different with your environment.
From: [email protected] [mailto:[email protected]] On Behalf Of S. Stein
Sent: Tuesday, June 26, 2012 11:34 AM
To: Jeffrey Gebhardt
Hi Jeff,
I have no idea where the /usr/bin/sh is coming from; perhaps it is an 'out of phase' error from a previous portion of the build(?).
I am not using cygwin, so \cygwin\bin is not in my path.
Sent: Tuesday, June 26, 2012 9:19:46 AM
Hi Josh,
/usr/bin/sh: ......binwin32-x86lemon.exe: command not found
where is the /usr/bin/sh: coming from in your error?  I don't think you
should get that from the cmd shell.  Do you have C:\cygwin\bin in your path?
Jeff
On 6/26/2012 10:46 AM, S. Stein wrote:
> Lewis:
> I'm doing my best to not build "a la carte" and use the support modules which come with the synApps tarball. If I can get that to build properly, I will then have the confidence to move on and upgrade individual components.
> Mark:
>    I am also using the 'cmd' shell.
>    It isn't clear to me what is happening here in my build on the last line - it appears the path is corrupted(?):
> perl -MExtUtils::Command -e rm_f ../O.Common/snl.bnf
> ..\\..\\..\\bin\\win32-x86\\lemon.exe o=. -g ../snl.lem>  ../O.Common/snl.bnf.tmp
> --J
> From: "Mark Rivers"<[email protected]>
> To: "[email protected]"<[email protected]>, [email protected]
> Sent: Tuesday, June 26, 2012 7:48:13 AM
> Hi Josh,
> I just rebuilt the sequencer on my Windows machine.  Here is the output from the same place where you are getting an error:
> "Installing created file ../../../bin/win32-x86/snc.exe"
> perl -MExtUtils::Command -e mv ../O.Common/snl.bnf.tmp ../O.Common/snl.bnf
> perl -MExtUtils::Command -e rm_f ../O.Common/bnf.inc
> perl ../bnf2txt.pl ../snl.re ../O.Common/snl.bnf>  ../O.Common/bnf.inc
> make[3]: Leaving directory `J:/epics/devel/seq-2-1-7/src/snc/O.win32-x86'
> make[2]: Leaving directory `J:/epics/devel/seq-2-1-7/src/snc'
> make[1]: Leaving directory `J:/epics/devel/seq-2-1-7/src'
> make -C ./test install
> make[1]: Entering directory `J:/epics/devel/seq-2-1-7/test'
> make -C ./compiler install
> make[2]: Entering directory `J:/epics/devel/seq-2-1-7/test/compiler'
> perl H:/epics/base-3.14.12.2/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
> perl -MExtUtils::Command -e mkpath O.Common
> make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
> make[3]: Entering directory `J:/epics/devel/seq-2-1-7/test/compiler/O.win32-x86'
> make[3]: Leaving directory `J:/epics/devel/seq-2-1-7/test/compiler/O.win32-x86'
> make[2]: Leaving directory `J:/epics/devel/seq-2-1-7/test/compiler'
> make -C ./pv install
> make[2]: Entering directory `J:/epics/devel/seq-2-1-7/test/pv'
> The command that failed for you was:
> The command that worked for me was:
> They look identical to me.
> What shell are you running in when you build?  I am running in the standard Windows "cmd" shell.
> Mark
> From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
> Sent: Tuesday, June 26, 2012 7:49 AM
> To: [email protected]
> Subject: SynApps build error : win32-x86
> Greetings all,
>    I'm having a maddening error attempting to build synApps_5_6 on a windows machine. Visual Studio 10, GnuWin32 Make (3.81), Strawberry Perl. The following is generated while attempting to build the sequencer support. Note the somewhat crazy mix of forward and backward slashes, the apparent use of double slashes within path names, and (the portion that appears to generate the failure) the lack of any slashes within the path to the "lemon" executable causing the "command not found" error.
> Generating code
> Finished generating code
> make[4]: *** [../O.Common/snl.bnf] Error 127
> make[4]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src/snc/O.win32-x86'
> make[3]: *** [install.win32-x86] Error 2
> make[3]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src/snc'
> make[2]: *** [snc.install] Error 2
> make[2]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src'
> make[1]: *** [src.install] Error 2
> make[1]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3'
> make: *** [c:/synApps_5_6/support/seq-2-1-3.install] Error 2
> make: Leaving directory `C:/synApps_5_6/support'
> Does anyone have an idea what is happening here?
> TIA,
> --Josh
Jeffrey Gebhardt
Beamline Controls and Data Acquisition
APS Engineering Support Division
630-252-5026
Re: SynApps build error : win32-x86 S. Stein
Re: SynApps build error : win32-x86 stein
Prev: Re: SynApps build error : win32-x86 stein
Next: Re: SynApps build error : win32-x86 Jeffrey Gebhardt
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: SynApps build error : win32-x86 S. Stein
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
