Hi Josh,
/usr/bin/sh: ......binwin32-x86lemon.exe: command not found
where is the /usr/bin/sh: coming from in your error? I don't think you
should get that from the cmd shell. Do you have C:\cygwin\bin in your path?
Jeff
On 6/26/2012 10:46 AM, S. Stein wrote:
Lewis:
I'm doing my best to not build "a la carte" and use the support modules which come with the synApps tarball. If I can get that to build properly, I will then have the confidence to move on and upgrade individual components.
Mark:
I am also using the 'cmd' shell.
It isn't clear to me what is happening here in my build on the last line - it appears the path is corrupted(?):
perl -MExtUtils::Command -e rm_f ../O.Common/snl.bnf
..\\..\\..\\bin\\win32-x86\\lemon.exe o=. -g ../snl.lem> ../O.Common/snl.bnf.tmp
--J
----- Original Message -----
To: "[email protected]"<[email protected]>, [email protected]
Sent: Tuesday, June 26, 2012 7:48:13 AM
Subject: RE: SynApps build error : win32-x86
Hi Josh,
I just rebuilt the sequencer on my Windows machine. Here is the output from the same place where you are getting an error:
"Installing created file ../../../bin/win32-x86/snc.exe"
perl -MExtUtils::Command -e mv ../O.Common/snl.bnf.tmp ../O.Common/snl.bnf
perl -MExtUtils::Command -e rm_f ../O.Common/bnf.inc
perl ../bnf2txt.pl ../snl.re ../O.Common/snl.bnf> ../O.Common/bnf.inc
make[3]: Leaving directory `J:/epics/devel/seq-2-1-7/src/snc/O.win32-x86'
make[2]: Leaving directory `J:/epics/devel/seq-2-1-7/src/snc'
make[1]: Leaving directory `J:/epics/devel/seq-2-1-7/src'
make -C ./test install
make[1]: Entering directory `J:/epics/devel/seq-2-1-7/test'
make -C ./compiler install
make[2]: Entering directory `J:/epics/devel/seq-2-1-7/test/compiler'
perl H:/epics/base-3.14.12.2/bin/win32-x86/makeMakefile.pl O.win32-x86 ../../..
perl -MExtUtils::Command -e mkpath O.Common
make -C O.win32-x86 -f ../Makefile TOP=../../.. T_A=win32-x86 install
make[3]: Entering directory `J:/epics/devel/seq-2-1-7/test/compiler/O.win32-x86'
make[3]: Leaving directory `J:/epics/devel/seq-2-1-7/test/compiler/O.win32-x86'
make[2]: Leaving directory `J:/epics/devel/seq-2-1-7/test/compiler'
make -C ./pv install
make[2]: Entering directory `J:/epics/devel/seq-2-1-7/test/pv'
The command that failed for you was:
The command that worked for me was:
They look identical to me.
What shell are you running in when you build? I am running in the standard Windows "cmd" shell.
-----Original Message-----
From: [email protected] [mailto:[email protected]] On Behalf Of [email protected]
Sent: Tuesday, June 26, 2012 7:49 AM
To: [email protected]
Subject: SynApps build error : win32-x86
Greetings all,
I'm having a maddening error attempting to build synApps_5_6 on a windows machine. Visual Studio 10, GnuWin32 Make (3.81), Strawberry Perl. The following is generated while attempting to build the sequencer support. Note the somewhat crazy mix of forward and backward slashes, the apparent use of double slashes within path names, and (the portion that appears to generate the failure) the lack of any slashes within the path to the "lemon" executable causing the "command not found" error.
Generating code
Finished generating code
make[4]: *** [../O.Common/snl.bnf] Error 127
make[4]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src/snc/O.win32-x86'
make[3]: *** [install.win32-x86] Error 2
make[3]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src/snc'
make[2]: *** [snc.install] Error 2
make[2]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3/src'
make[1]: *** [src.install] Error 2
make[1]: Leaving directory `c:/synApps_5_6/support/seq-2-1-3'
make: *** [c:/synApps_5_6/support/seq-2-1-3.install] Error 2
make: Leaving directory `C:/synApps_5_6/support'
C:\synApps_5_6\support>
Does anyone have an idea what is happening here?
TIA,
--Josh
Jeffrey Gebhardt
Beamline Controls and Data Acquisition
APS Engineering Support Division
630-252-5026
- Re: SynApps build error : win32-x86 S. Stein
<2012>
<2012>
