1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: XOFF Problem with tyGSOctal
To: "Bjorklund, Eric A" <[email protected]>
Cc: EPICS tech-talk <[email protected]>
Date: Mon, 25 Jun 2012 08:20:19 -0700
While ASYN/termios does support it, XOFF/XON is a notoriously unreliable flow control mechanism.
Is there really no way to disable this behaviour from the power supply?   Could you run at a slower serial line speed and avoid the handshaking?
On Jun 25, 2012, at 6:07 AM, Dirk Zimoch wrote:
> Bjorklund, Eric A wrote:
>> For the first time in our experience, we have a serial device (Kepco power supply) that insists on sending XOFF/XON sequences.  We are using streamDevice and a Greenspring Octal IP module to talk to it.  StreamDevice and Asyn appear to have no problems with the XOFF/XON characters, however the tyGSOctalStartup routine in tyGSOctal.c puts out a continuous stream of
>> "tyITX ERROR, sr=0c" errors.  The cause of these errors turns out to be
>> that the tyITx() routine (a vxWorks function) returns ERROR if it is called to start a transmission and the transmitter is XOFF'd.
>> This causes the tyGSOctalStartup routine to log an error -- perhaps because it thinks someone is trying to send a zero-length buffer (no characters left to transmit is the other reason tyITx() will return ERROR).
>> The easiest way to fix the problem was just to remove the error message (see attached patch file -- which only comments out the offending code in case that turns out to be a bad idea).  As far as we can tell, there are no ill effects from this.  We seem to be talking to the power supply just fine.
>> Anybody see a reason why we should leave the error report in tyGSOctalStartup() ?
>> Thanks,
>> -Eric Bj
> Eric,
> XON/XOFF should be resolved on a lower level than StreamDevice and even asyn. In asyn versions >= 4.17 you can control XOFF/XON behavior on the OS driver level:
> asynSetOption ("port", 0, "ixon", "Y")
> Now, the device should not forward XON to asyn/StreamDevice but instead block the write function until the device is free again (I hope).
> Dirk
Eric Norum
[email protected]
XOFF Problem with tyGSOctal Bjorklund, Eric A
Re: XOFF Problem with tyGSOctal Dirk Zimoch
Prev: RE: Large waveform PV through CA Gateway Chen, Xihui
Next: FW: Large waveform PV through CA Gateway Hill, Jeff
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: XOFF Problem with tyGSOctal Dirk Zimoch
Next: Re: XOFF Problem with tyGSOctal Bjorklund, Eric A
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
