1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS and MEDM on ubuntu
To: Dirk Zimoch <[email protected]>
Cc: nalaka samarasinghe <[email protected]>, [email protected]
Date: Mon, 25 Jun 2012 09:57:24 -0500
On 6/25/12 7:53 AM, Dirk Zimoch wrote:
> Hello Nalaka
> First get EPICS base fixed before you try to do MEDM.
> When compiling base, you got:
>> make[3]: /usr/bin/g++: Command not found
> This looks very bad. Make sure g++ is installed. I was quite
> sure that this is installed on Ubuntu by default, but maybe I am
> wrong. Or it is installed somewhere else? If it installed
> somewhere else, you need to fix the path in the EPICS makefile,
> which is complicated for a beginner.
I don't think build tools come installed by default on Ubuntu.
You need to install the "build-essential" package to get those
tools.
To build EPICS Base with readline support, I think you also need
to install the libreadline-dev package.
BTW, there's an introductory page about compiling software on
Ubuntu at
  https://help.ubuntu.com/community/CompilingEasyHowTo
.  If you want to build things beyond EPICS Base, such as MEDM
and synApps, you will likely need to install even more packages.
 My list is for Ubuntu 8.04.3 LTS, so it's very old, but for it
I needed to install flex, libx11-dev, and libxmu-dev from the
"main" repo, and I needed to install lesstif2 and lesstif2-dev
from the "universe" repo.
Lewis
EPICS and MEDM on ubuntu nalaka samarasinghe
Re: EPICS and MEDM on ubuntu Dirk Zimoch
Prev: Large waveform PV through CA Gateway Chen, Xihui
Next: Re: Large waveform PV through CA Gateway Dirk Zimoch
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: EPICS and MEDM on ubuntu Dirk Zimoch
Next: XOFF Problem with tyGSOctal Bjorklund, Eric A
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
