g+
g+ Communities
Argonne National Laboratory
1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: EPICS and MEDM on ubuntu
To: tech-talk@aps.anl.gov
Date: Sun, 24 Jun 2012 15:52:44 +0530
Hi Everyone,
I am new to EPICS and i am trying to install EPICS and medm on ubuntu
linux 10.04. I use your method as a guide in installation.
when i am compiling epics following output appears and when trying to
compile MEDM also following output results. I really appreciate if you
could support me to make this work.
Thank you
Screen that appears after compiling  MEDM
nalaka@nalaka-laptop:/opt/epics/extensions/src/medm$ make
make -C ./printUtils install
make[1]: Entering directory
`/opt/epics/extensions/src/medm3_1_4/printUtils'
make -C O.linux-x86 -f ../Makefile TOP=../../../.. T_A=linux-x86 install
make[2]: Entering directory
`/opt/epics/extensions/src/medm3_1_4/printUtils/O.linux-x86'
make[2]: Nothing to be done for `install'.
make[2]: Leaving directory
make[1]: Leaving directory
make -C ./xc install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/xc'
`/opt/epics/extensions/src/medm3_1_4/xc/O.linux-x86'
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/xc'
make -C ./medm install
make[1]: Entering directory `/opt/epics/extensions/src/medm3_1_4/medm'
`/opt/epics/extensions/src/medm3_1_4/medm/O.linux-x86'
/usr/bin/gcc -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_XOPEN_SOURCE=500           -D_X86_  -DUNIX  -D_BSD_SOURCE -Dlinux
-D_REENTRANT -ansi   -O3   -Wall     -DSCIPLOT -DMOTIF -DEDITRES  -m32
-g  -I. -I../O.Common -I. -I.. -I../../../../include/os/Linux
-I../../../../include -I/opt/epics/base/include/os/Linux
-I/opt/epics/base/include        -I../../printUtils -I../../xc
-I/usr/include -I/usr/include/X11    ../medmCartesianPlot.c
In file included from ../medm.h:104,
                 from ../medmCartesianPlot.c:58:
../medmCA.h:34:19: error: cadef.h: No such file or directory
../medmCA.h:35:23: error: db_access.h: No such file or directory
../medmCA.h:36:50: error: alarm.h: No such file or directory
../medmCA.h:48: error: field ‘s’ has incomplete type
../medmCA.h:49: error: field ‘e’ has incomplete type
../medmCA.h:50: error: field ‘c’ has incomplete type
../medmCA.h:51: error: field ‘i’ has incomplete type
../medmCA.h:52: error: field ‘l’ has incomplete type
../medmCA.h:53: error: field ‘f’ has incomplete type
../medmCA.h:54: error: field ‘d’ has incomplete type
../medmCA.h:69: error: field ‘s’ has incomplete type
../medmCA.h:70: error: field ‘e’ has incomplete type
../medmCA.h:71: error: field ‘c’ has incomplete type
../medmCA.h:72: error: field ‘i’ has incomplete type
../medmCA.h:73: error: field ‘l’ has incomplete type
../medmCA.h:74: error: field ‘f’ has incomplete type
../medmCA.h:75: error: field ‘d’ has incomplete type
../medmCA.h:94: error: expected specifier-qualifier-list before
‘TS_STAMP’
../medmCA.h:109: error: expected specifier-qualifier-list before ‘chid’
In file included from ../medmCartesianPlot.c:73:
../medmCartesianPlot.h:83: error: expected specifier-qualifier-list
before ‘TS_STAMP’
../medmCartesianPlot.c: In function
‘cartesianPlotCreateRunTimeInstance’:
../medmCartesianPlot.c:193: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:194: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:195: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
‘cartesianPlotUpdateGraphicalInfoCb’:
../medmCartesianPlot.c:360: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cartesianPlotUpdateTrace’:
../medmCartesianPlot.c:415: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c:546: error: ‘DBF_STRING’ undeclared (first use in
this function)
../medmCartesianPlot.c:546: error: (Each undeclared identifier is
reported only once
../medmCartesianPlot.c:546: error: for each function it appears in.)
../medmCartesianPlot.c:554: error: ‘DBF_INT’ undeclared (first use in
this function)
../medmCartesianPlot.c:563: error: ‘DBF_FLOAT’ undeclared (first use in
this function)
../medmCartesianPlot.c:572: error: ‘DBF_ENUM’ undeclared (first use in
this function)
../medmCartesianPlot.c:581: error: ‘DBF_CHAR’ undeclared (first use in
this function)
../medmCartesianPlot.c:590: error: ‘DBF_LONG’ undeclared (first use in
this function)
../medmCartesianPlot.c:592: error: ‘dbr_long_t’ undeclared (first use in
this function)
../medmCartesianPlot.c:592: error: ‘pLong’ undeclared (first use in this
function)
../medmCartesianPlot.c:592: error: expected expression before ‘)’ token
../medmCartesianPlot.c:599: error: ‘DBF_DOUBLE’ undeclared (first use in
this function)
../medmCartesianPlot.c:643: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:645: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:646: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:646: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:648: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:649: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:650: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:674: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:682: error: ‘Record’ has no member named ‘time’
../medmCartesianPlot.c:683: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:759: error: expected expression before ‘)’ token
../medmCartesianPlot.c:836: error: expected expression before ‘)’ token
../medmCartesianPlot.c:920: error: expected expression before ‘)’ token
../medmCartesianPlot.c:968: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:969: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:971: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:972: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:974: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:976: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:982: error: expected expression before ‘)’ token
../medmCartesianPlot.c:983: error: expected ‘;’ before ‘offset’
../medmCartesianPlot.c:987: error: ‘offset’ undeclared (first use in
this function)
../medmCartesianPlot.c:997: error: ‘MedmCartesianPlot’ has no member
named ‘startTime’
../medmCartesianPlot.c:1069: error: expected expression before ‘)’ token
‘cartesianPlotUpdateScreenFirstTime’:
../medmCartesianPlot.c:1103: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cartesianPlotUpdateValueCb’:
../medmCartesianPlot.c:1245: error: ‘Record’ has no member named
‘clientData’
../medmCartesianPlot.c: In function ‘cpAxisOptionMenuSimpleCallback’:
../medmCartesianPlot.c:2252: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:2259: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
../medmCartesianPlot.c:2269: error: ‘MedmCartesianPlot’ has no member
named ‘timeScale’
make[2]: *** [medmCartesianPlot.o] Error 1
make[1]: *** [install.linux-x86] Error 2
make[1]: Leaving directory `/opt/epics/extensions/src/medm3_1_4/medm'
make: *** [medm.install] Error 2
Screen that appears after compiling EPICS
nalaka@nalaka-laptop:/opt/epics/base$ make
make -C ./configure install
make[1]: Entering directory `/opt/epics/base-3.14.10/configure'
make -C O.linux-x86 -f ../Makefile TOP=../.. T_A=linux-x86 install
`/opt/epics/base-3.14.10/configure/O.linux-x86'
make[1]: Leaving directory `/opt/epics/base-3.14.10/configure'
make -C ./src install
make[1]: Entering directory `/opt/epics/base-3.14.10/src'
make -C ./tools install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/tools'
make -C O.linux-x86 -f ../Makefile TOP=../../.. T_A=linux-x86 install
make[3]: Entering directory
`/opt/epics/base-3.14.10/src/tools/O.linux-x86'
make[3]: Nothing to be done for `install'.
make[3]: Leaving directory
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/tools'
make -C ./makeBaseApp install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/makeBaseApp'
`/opt/epics/base-3.14.10/src/makeBaseApp/O.linux-x86'
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/makeBaseApp'
make -C ./makeBaseExt install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/makeBaseExt'
`/opt/epics/base-3.14.10/src/makeBaseExt/O.linux-x86'
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/makeBaseExt'
make -C ./libCom install
make[2]: Entering directory `/opt/epics/base-3.14.10/src/libCom'
`/opt/epics/base-3.14.10/src/libCom/O.linux-x86'
/usr/bin/g++ -c   -D_POSIX_C_SOURCE=199506L -D_POSIX_THREADS
-D_REENTRANT -ansi   -O3   -Wall      -m32     -g -fPIC -I.
-I../O.Common -I. -I../../../src/libCom/osi/os/Linux
-I../../../src/libCom/osi/os/posix -I../../../src/libCom/osi/os/default
-I.. -I../../../src/libCom/bucketLib -I../../../src/libCom/ring
-I../../../src/libCom/calc -I../../../src/libCom/cvtFast
-I../../../src/libCom/cppStd -I../../../src/libCom/cxxTemplates
-I../../../src/libCom/dbmf -I../../../src/libCom/ellLib
-I../../../src/libCom/env -I../../../src/libCom/error
-I../../../src/libCom/fdmgr -I../../../src/libCom/freeList
-I../../../src/libCom/gpHash -I../../../src/libCom/iocsh
-I../../../src/libCom/logClient -I../../../src/libCom/macLib
-I../../../src/libCom/misc -I../../../src/libCom/osi
-I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I../../../include/os/Linux
-I../../../include         ../../../src/libCom/ring/epicsRingPointer.cpp
make[3]: /usr/bin/g++: Command not found
make[3]: *** [epicsRingPointer.o] Error 127
make[2]: *** [install.linux-x86] Error 2
make[2]: Leaving directory `/opt/epics/base-3.14.10/src/libCom'
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/opt/epics/base-3.14.10/src'
make: *** [src.install] Error 2
Re: EPICS and MEDM on ubuntu Dirk Zimoch
Prev: Processing And Visualization of time series data. Mihaylov, Miroslav N.
Next: XOFF Problem with tyGSOctal Bjorklund, Eric A
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Processing And Visualization of time series data. Miroslav Mihaylov
Next: Re: EPICS and MEDM on ubuntu Dirk Zimoch
ANJ, 27 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
