1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Re: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP
To: [email protected]
Date: Fri, 22 Jun 2012 22:04:36 +0900
HI,
I tried commenting out "vxWorks-ppc604_long" in $EPICS_BASE/configure/os/CONFIG_SITE.cygwin-x86.Common file.
Run "make"
make -C configure install
make[1]: Entering directory '/cygdrive/c/epics/base-3.14.11/configure'
perl ../configure/tools/makeMakefile.pl O.cygwin-x86 ../..
perl ../configure/tools/makeMakefile.pl O.vxWorks-ppc604 ../.   <===  Ok. vxWorks-ppc604 was created.
But..
I got the following error.
-I../../../src/libCom/misc -I../../../src/libCom/osi -I../../../src/libCom/taskwd -I../../../src/libCom/timer
-I../../../src/libCom/tsDefs -I../../../include/os/vxWorks  -I../../../include
-I/cygdrive/c/Tornado2.2/target/h  ../../../src/libCom/bucketLib/bucketLib.c
C:\Tornado2.2\host\x86-win32\bin\ccppc.exe: *** conflicting versions of cygwin1.dll detected.  Use only the most recent version.
../../../configure/RULES_BUILD:178: recipe for target `bucketLib.o' failed
make[3]: *** [bucketLib.o] Segmentation fault
make[3]: Leaving directory `/cygdrive/c/epics/base-3.14.8.2/src/libCom/O.vxWorks-ppc604'
../../configure/RULES_ARCHS:37: recipe for target `install.vxWorks-ppc604' failed
make[2]: *** [install.vxWorks-ppc604] Error 2
make[2]: Leaving directory `/cygdrive/c/epics/base-3.14.8.2/src/libCom'
../configure/RULES_DIRS:41: recipe for target `libCom.install' failed
make[1]: *** [libCom.install] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/base-3.14.8.2/src'
configure/RULES_DIRS:41: recipe for target `src.install' failed
make: *** [src.install] Error 2
I found that there are the same cygwin1.dll files in C:\cygwin\bin and C:\Tornado2.2\host\x86-win32\bin.
So, i replaced the name in C:\Tornado2.2\host\x86-win32\bin with another name, "cygwin1.dll.tornado".
Run "make" again.
I got the same error in base-3.14.8.2, base-3.14.10 and base-3.14.11.
Installing created file ../../../bin/cygwin-x86/caRepeater.exe
Installing created file ../../../bin/cygwin-x86/catime.exe
Installing created file ../../../bin/cygwin-x86/acctst.exe
Installing created file ../../../bin/cygwin-x86/caConnTest.exe
Installing created file ../../../bin/cygwin-x86/casw.exe
Installing created file ../../../bin/cygwin-x86/caEventRate.exe
Installing html ../../../html//CAref.html
make[3]: Leaving directory `/cygdrive/c/epics/base-3.14.10/src/ca/O.cygwin-x86'
make -C O.vxWorks-ppc604_long -f ../Makefile TOP=../../.. T_A=vxWorks-ppc604_long install
make[3]: Entering directory `/cygdrive/c/epics/base-3.14.10/src/ca/O.vxWorks-ppc604_long'
/cygdrive/c/Tornado2.2/host/x86-win32/bin/ccppc -c             -DCPU=PPC604  -DvxWorks -include /cygdrive/c/Tornado2.2/target/h/vxWorks.h  -ansi   -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks  -I../../../include       -I/cygdrive/c/Tornado2.2/target/h  ../catime.c
/cygdrive/c/Tornado2.2/host/x86-win32/bin/ccppc -c             -DCPU=PPC604  -DvxWorks -include /cygdrive/c/Tornado2.2/target/h/vxWorks.h  -ansi   -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall    -fno-builtin  -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks  -I../../../include       -I/cygdrive/c/Tornado2.2/target/h  ../acctst.c
/cygdrive/c/Tornado2.2/host/x86-win32/bin/ccppc -c             -DCPU=PPC604  -DvxWorks -include /cygdrive/c/Tornado2.2/target/h/vxWorks.h  -ansi   -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks  -I../../../include       -I/cygdrive/c/Tornado2.2/target/h  ../caConnTest.cpp
/cygdrive/c/Tornado2.2/host/x86-win32/bin/ccppc -c             -DCPU=PPC604  -DvxWorks -include /cygdrive/c/Tornado2.2/target/h/vxWorks.h  -ansi   -O2   -Wall     -mcpu=604 -mstrict-align -mno-implicit-fp -mlongcall -fno-implicit-templates   -fno-builtin  -I. -I../O.Common -I. -I.. -I../../../include/os/vxWorks  -I../../../include       -I/cygdrive/c/Tornado2.2/target/h  ../casw.cpp
../include       -I/cygdrive/c/Tornado2.2/target/h  ../caEventRate.cpp
make[3]: stat: ../../../lib/vxWorks-ppc604_long/libCom.a: Too many levels of symbolic links
make[3]: *** `libca.a'에서 필요로 하는  타겟 `../../../lib/vxWorks-ppc604_long/libCom.a'를 만들 규칙이 없습니다.  멈춤.
make[3]: Leaving directory `/cygdrive/c/epics/base-3.14.10/src/ca/O.vxWorks-ppc604_long'
../../configure/RULES_ARCHS:60: recipe for target `install.vxWorks-ppc604_long' failed
make[2]: *** [install.vxWorks-ppc604_long] Error 2
make[2]: Leaving directory `/cygdrive/c/epics/base-3.14.10/src/ca'
../configure/RULES_DIRS:65: recipe for target `ca.install' failed
make[1]: *** [ca.install] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/base-3.14.10/src'
configure/RULES_DIRS:65: recipe for target `src.install' failed
I checked the folder, "$EPICS_BASE/lib/vxWorks-ppc60_long"
$ ls -al
drwxr-xr-x   1 Administrator  0 Jun 22 21:14 .
drwxr-xr-x   1 Administrator  0 Jun 22 21:14 ..
drwxrwxrwx 1 Administrator  8 Jun 22 21:14 libCom.a  -> libCom.a
The libCom.a was linked to oneself.
I think it is incorrect!!
What is problems?
In the same compile environment, the base-3.14.12 has different errors from above errors.
gcc -c  -D_POSIX_THREADS -D_POSIX_TIMERS         -DDEFAULT_SKELETON_FILE=include/flex.skel.static   -DUNIX  -DCYGWIN32     -O3   -w      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/cygwin32  -I../../../../include        ../sym.c
gcc -c  -D_POSIX_THREADS -D_POSIX_TIMERS         -DDEFAULT_SKELETON_FILE=include/flex.skel.static   -DUNIX  -DCYGWIN32     -O3   -w      -m32    -D_DLL   -MMD -I. -I../O.Common -I. -I.. -I../../../../include/os/cygwin32  -I../../../../include        ../tblcmp.c
rm -f parse.c y.tab.c
rm -f parse.h y.tab.h
../../../../bin/cygwin-x86/antelope.exe -l -d ../parse.y
../../../../configure/RULES_BUILD:229: recipe for target `parse.c' failed
make[4]: *** [parse.c] Error 127
make[4]: Leaving directory `/cygdrive/c/epics/base-3.14.12.2/src/toolsComm/flex/O.cygwin-x86'
../../../configure/RULES_ARCHS:63: recipe for target `install.cygwin-x86' failed
make[3]: *** [install.cygwin-x86] Error 2
make[3]: Leaving directory `/cygdrive/c/epics/base-3.14.12.2/src/toolsComm/flex'
../../configure/RULES_DIRS:70: recipe for target `flex.install' failed
make[2]: *** [flex.install] Error 2
make[2]: Leaving directory `/cygdrive/c/epics/base-3.14.12.2/src/toolsComm'
../configure/RULES_DIRS:70: recipe for target `toolsComm.install' failed
make[1]: *** [toolsComm.install] Error 2
make[1]: Leaving directory `/cygdrive/c/epics/base-3.14.12.2/src'
configure/RULES_DIRS:70: recipe for target `src.install' failed
The base-3.14.9 was successfully compiled.
But i'm not sure because it is not carried out on the baseboard (mv5100).
The tool version i use is below.
$ uname.exe  -a
CYGWIN_NT-5.1 ygsong72 1.7.15(0.260/5/3) 2012-05-09 10:25 i686 Cygwin
$ gcc -v
Using built-in specs.
COLLECT_GCC=gcc
COLLECT_LTO_WRAPPER=/usr/lib/gcc/i686-pc-cygwin/4.5.3/lto-wrapper.exe
Target: i686-pc-cygwin
gcc version 4.5.3 (GCC)
Please tell me what I did incorrectly?
Thanks in advance.
Young-gi
-----Original Message-----
보낸사람(From) : Andrew Johnson <[email protected]>
받는사람(To) : [email protected]
참조(Cc) : 송영기<[email protected]>
보낸일자(Sent) : 2012-06-22
메일제목(Subject) : Re: Is it possible to create a cross-compile environment using cygwin and vxWorks on Windows XP
It should be possible to cross-build for vxWorks from Cygwin, I suspect you
just need to make some configuration file changes.
On 2012-06-21 송영기 wrote:
> I want to have a target IOC for mvme5100 using cygwin and vxWorks5.5
>  (Tornado2.2) on Windows XP. My base compile produces only cygwin-x86
>  binary and library files, such as $EPISC_BASE/bin/cygwin-x86 and
>  $EPISC_BASE/lib/cygwin-x86. There is no vxWorks-ppc604 binary and library
>  for target board.
> I edited base config files below.
> - configure/CONFIG_SITE
>   : CROSS_COMPILER_TARGET_ARCH=vxWorks-ppc604
That name should be CROSS_COMPILER_TARGET_ARCHS, I suspect you just typed it
wrong in your email though.
I suspect the problem is that the value for CROSS_COMPILER_TARGET_ARCHS that
you set in CONFIG_SITE gets overridden in the file
configure/os/CONFIG_SITE.cygwin-x86.Common where it currently gets set to
empty by default (this is a bug which I will fix).  Try commenting out the
setting in that file, or moving it there instead, then run 'make' from the top
directory again.
You might need to change your vxWorks target architecture and use the one
called vxWorks-ppc604_long instead, since MVME5100 boards have more than 32MB
of RAM.  You'll know that is the case if you see the error "Relocation value
does not fit in 24 bits." when the startup script loads the IOC's .munch file.
There is more information about this issue at
    http://www.aps.anl.gov/epics/base/ppc.php#Relocation
I hope this helps,
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Prev: RE: put callback queuing matthew.pearson
Next: Processing And Visualization of time series data. Mihaylov, Miroslav N.
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
