1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw
To: Yoram Fisher <[email protected]>
Cc: [email protected]
Date: Wed, 6 Jun 2012 17:09:44 -0500
Hi Yoram,
On 2012-06-06 Yoram Fisher wrote:
> I am attempting to build EPICS 3.14.12.2 on a Windows XP machine using
>  mingw32. EPICS_HOST_ARCH = win32-x86-mingw
> I type"make" at the top level directory (c:\epics).  Make is GNU Make
>  version 3.81 I get an error: /bin/ld.exe: cannot find -lrtemscpu
I see that you're trying to cross-compile for the RTEMS-uC5282 target on your
win32-x86-mingw host.  I have to admit I've not heard of anyone doing that
before, although there's no fundamental reason that it won't work.  It might
need a little tweaking of the configuration files though since you're a
pioneer in this AFAIK.
> The closest matching file I have on my machine is librtemscpu.a.
That's actually the file it's looking for, the -lrtemscpu option tells the
compiler to link the code with a library called librtemscpu.a which it will
find by looking through the paths given it in -L options or through its built-
in search path.  Let's look at the command line you posted:
> /c/opt/rtems-4.10/bin/m68k-rtems4.10-g++ -o rtemsTestHarness -static
>  -L/c/epics/lib/RTEMS-uC5282         -mcpu=5282 -u Init /lib/no-dpmem.rel
>  /lib/no-mp.rel /lib/no-part.rel /lib/no-signal.rel /lib/no-rtmon.rel
>        rtemsTestHarness.o epicsCalcTest.o epicsAlgorithmTest.o
>  epicsMathTest.o epicsEllTest.o epicsErrlog Test.o epicsStdioTest.o
>  epicsStringTest.o epicsTimeTest.o epicsThreadTest.o epic sThreadOnceTest.o
>  epicsThreadPriorityTest.o epicsThreadPrivateTest.o epicsExitTe st.o
>  epicsTimerTest.o ringPointerTest.o ringBytesTest.o epicsEventTest.o
>  epicsMu texTest.o epicsExceptionTest.o macEnvExpandTest.o macLibTest.o
>  taskwdTest.o bloc kingSockTest.o epicsMessageQueueTest.o
>  epicsRunLibComTests.o epicsThreadPerform. o epicsMaxThreads.o buckTest.o
>  cvtFastPerform.o    -lCom       -lm -lrtemsCom -l c -lrtemscpu -lCom -lnfs
>  -lm
> c:/opt/rtems-4.10/bin/../lib/gcc/m68k-rtems4.10/4.4.7/../../../../m68k-rtem
>  s4.10/bin/ld.exe: cannot find -lrtemscpu
When I build that same file on my Linux system those .rel arguments starting
at the end of the second line above all begin with the full path to my RTEMS
installation.  I'm not sure if that's relevant, but it looks a little fishy to
me (unless you really have several files called no-*.rel in your /lib
directory).
You might want to post the contents of the CONFIG*RTEMS-uc5282 files you had
to create in the base/configure/os directory to get the build to go as far as
you have, I suspect there's something missing there and with that information
we should be able to help you fix this.
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
RE: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
Prev: Re: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Eric Norum
Next: Re: a MEDM replacement J. Lewis Muir
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: EPICS Compile error: cannot find -lrtemscpu on Windows using mingw Yoram Fisher
ANJ, 18 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
